12V Battery Options for Wireless Follow Focus
#1 Allen Achterberg
Allen Achterberg
  • 437 posts
  • Santa Maria CA
Posted 03 December 2016 - 03:19 AM
I've got a Cinegears Follow Focus, and need to run off of a smaller 3 axis gimbal that offers no power solutions, what lightweight battery options are there that feature a D-Tap power output? I've googled, and found nothing spot on. anyone have any insight?
thanks
#2 Sid Tinney
Sid Tinney
  • 2 posts
  • Australia
Posted 06 December 2016 - 08:26 PM
Which gimbal is it?
Whatever you end up doing will likely require a bit of soldering. Assuming you have some Canon LP's kicking around, the most straightforward is probably to get one of these LP-E6>12V converters, then convert the barrel plug to whatever power input the Cinegears takes (I think Lemo?)
If you have a basic knowledge of soldering it should be fairly simple to rig up a cheaper solution using a generic LP-E6 battery plate and a 12V voltage reg, you'll come up with the same result. The process should also be fairly similar for other batteries (Sony NP's, hobby LiPo's etc)
Whatever you end up doing I'd recommend doing some weight testing first, because there's no point wasting the time trying to make it work if you can't balance the rig in the first place.
Edited by Sid Tinney, 06 December 2016 - 08:26 PM.
