HD Depth of Field Charts
11 replies to this topic
#1 Stephen Whitehead
Stephen Whitehead
  • 124 posts
  • Toronto, Canada
Posted 17 June 2005 - 08:00 PM
Hey, does anyone know where about a depth of field chart for HD, namely the CineAlta can be found?
Cheers,
Steve
#2 Mike Brennan
Mike Brennan
  • 581 posts
Posted 18 June 2005 - 03:16 PM
Hi Steven,
I suggest that you make your own notes.
In doing so you'll learn how the focus falls off slowly especially on wider lenses and the effect of in-camera detail on out of focus backgrounds.
1920x1080 LCD display should do the trick for you.
Mike Brennan
#3 Stephen Whitehead
Stephen Whitehead
  • 124 posts
  • Toronto, Canada
Posted 18 June 2005 - 05:14 PM
Now I am familier of course with wider angle lenses' effects on DOF. My thing is that I have worked mostly with 35mm, and 16mm and now am being asked to shoot HD. What exactly do you mean by the cameras effect on background detail? is there some sort of filter that the camera applies?
Cheers,
Steve
#4 Dudu Stoz
Dudu Stoz
  • 39 posts
Posted 20 June 2005 - 10:06 AM
the DOF calculation on HD are the same as with film exept circle of confusion is 15 micron.
#5 Dudu Stoz
Dudu Stoz
  • 39 posts
Posted 20 June 2005 - 10:15 AM
Mike Brennan
<{POST_SNAPBACK}>
sorry,
but the in camera detail has nothing to do with soft focus in the background(or in the forgound) it is the electronic detail enhancing of sharp objects - to be precice the detail enhancing circle drowin black an white lines arround lines where video level or croma vector changes radicaly.
#6 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 20 June 2005 - 10:34 AM
sorry,
<{POST_SNAPBACK}>
However too much detail will make everything look sharper. If you have good lenses you should be able to turn off the detail!
Stephen
#7 Dudu Stoz
Dudu Stoz
  • 39 posts
Posted 20 June 2005 - 05:40 PM
Stephen
<{POST_SNAPBACK}>
well for my opinion the detail enhancment is good for anything to be broadcast in television, with detail off it will look too soft even with a sharp lens - but for anything going to teathral release the detail correction is too visible so it is better to turn it off as you said
#8 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 21 June 2005 - 02:02 AM
<{POST_SNAPBACK}>
We are talking about a Cine Alta camera! The Panavision default is off as no extra detail is required as the lenses are so sharp. But for a video camera with a cheap zoom lens, well thats another story.
Stephen
#9 Mike Brennan
Mike Brennan
  • 581 posts
Posted 21 June 2005 - 04:18 PM
sorry,
<{POST_SNAPBACK}>
Nothing to do with soft background?
Try it and see if it has no effect on the background.
Mike Brennan
#10 Mike Brennan
Mike Brennan
  • 581 posts
Posted 21 June 2005 - 04:28 PM
<{POST_SNAPBACK}>
It is dangerous quoting depth of field numbers made for film.
Although the theory of optics is the same, HD capture and display is different than film, for which the depth of field charts were designed (someone correct me if I'm wrong here)
The "apparent" depth of field decreases with the resolution of the display.
So it could be less on HD, when viewed on a HD display or digital projector than on 16mm projected on film.
Ask yourself,
Who created the depth of field tables?
captured on what medium?
and viewed on what display?
Mike Brennan
#11 David Mullen ASC
  • 20072 posts
Posted 21 June 2005 - 04:38 PM
Ask yourself,
Mike Brennan
<{POST_SNAPBACK}>
Now you understand why I believe depth of field charts will always only be an approximation anyway. Too many variables, too many end product destinations.
Anything that is critical should be tested for the worst-case final viewing format, otherwise just understand that it's only a ballpark calculation.
#12 Dudu Stoz
Dudu Stoz
  • 39 posts
Posted 22 June 2005 - 06:35 AM
<{POST_SNAPBACK}>
15 micron CoC calculation is the number that will suit for the worst-case viewing format.
because unlike in film focus is not a defenitive thing it ranges within the size of the pixel
which is ~ 14 micron in HDCAM - so if a dot of light sourse focuses inside 1 pixel it is no mather how big the screening projection will be, the dot will only fill this one pixel,
which i think makes this DoF calculation a definitive thing.
