RED One MX Can't Shoot 120?
#1 Macks Fiiod
Macks Fiiod
  • 1507 posts
  • Og from DC, Now in NJ
Posted 03 January 2017 - 10:22 PM
Hey, I've been on and off trying to set this up for nearly a year now.
I've had the camera set at 2k 16:9 (and I think 2:1), Redcode28, and when I go to frame rate the option for 120p doesn't show up.
Has anyone else ran into this problem? How would I fix it?
Thank you.
#2 Devindra Sooknanan
Devindra Sooknanan
  • 25 posts
  • Bay area, california
Posted 14 January 2017 - 01:11 AM
hey, i don't think it'll work on 16:9  i got it to work on 2k 2:1 at redcode 36
#3 Devindra Sooknanan
Devindra Sooknanan
  • 25 posts
Posted 14 January 2017 - 03:27 AM
#4 Macks Fiiod
Macks Fiiod
  • 1507 posts
Posted 14 January 2017 - 05:52 PM
I had it at those exact setting here, I keep twisting it clockwise and all I'm able to see is 59.94.
Is there another setting I'm missing? Do I need to upgrade something?
It's recording to the RED hard disk drive and not an SSD, if that makes a difference.
#5 Devindra Sooknanan
Devindra Sooknanan
  • 25 posts
Posted 15 January 2017 - 01:03 AM
did you set the frame rate under the varispeed menu? if not try this.
system-> project -> configure -> time base: set to 23.97
then
Sensor-> varispeed-> frame rate:  set the frame rate to 120
check the varispeed box.
  • 1
#6 Macks Fiiod
Macks Fiiod
  • 1507 posts
Posted 15 January 2017 - 03:12 AM
There it is, thank you!
#7 Devindra Sooknanan
Devindra Sooknanan
  • 25 posts
Posted 15 January 2017 - 06:41 AM
right on yo.  btw if you have an external trigger check the ramp box and set it to event then go to the gpio settings and change it from record to ramp then you can start at 24fps at the start of the clip and when you press the trigger it'll go to 120
