Video Artifact - editor to remove compression artifacts and noise
software
#1 rean
rean
Posted 03 January 2017 - 11:16 PM
Video Artifact is a new standalone video editor for digital film restoration and footage quality enhancement.
http://www.videoartifact.com/va/
This program helps you to prepare footages from consumer or professional video cameras, digicams and V-DSLR. It can remove MJPEG, MPEG, H.264, H.265 compression artifacts and digital noise, improves sharpness and color resolution up to 16 bit 4:4:4.
Some quality restoration features:
  • Script-based to work with unique cases. You can use many filters in any combination.
  • 50+ specialized restoration filters work in Y, U, V separately in 8/16 bit.
  • Possibility to use dozens of different type denoisers for different noise type.
  • Accurate denoising that keeps micro details with no "plastic" effect.
  • Removing of sharping halos.
  • Linear color high quality spline-based resize to resize up to 4K. Resize halos can be removed.
  • Precise halo-free radius-dependent sharping.
  • Film grain emulation and 3D LUT grading.
  • 4:2:0 8 bit to 4:2:2/4:4:4 16 bit chroma reconstruction.
It can be used in a post-production workflow if you use V-DSLR or consumer cameras. Currently 50+ camera models supported and hundreds of compatible models. Some special features:
  • Batch processing without GPU. Very fast: 5 fps for typical V-DSLR AVCHD source and 2 fps for 4K.
  • Automatic joining of MTS, MOV and MP4 spans and renaming to yyyymmdd_hhmmss.mov format.
  • Non-standard 16-255 to TV 16-235 levels conversion.
  • ITU-R BT.601 ↔ BT.709 floating point conversion.
  • NLE and DaVinci Resolve compatible workflow.
  • Mastering to webm VP9/Opus or mp4 H.264/AAC 1080p/720p/360p/240p.
Examples with various restoration methods: http://www.videoartifact.com/examples/ You can download low compressed videos there to see actual quality.
More examples:
#2 Macks Fiiod
Macks Fiiod
  • 1509 posts
  • Og from DC, Now in NJ
Posted 10 February 2017 - 06:30 AM
So is anyone actually buying this? Seems too good to be true.
