Zeiss zf2 on Bolex H16
#1 Mendes Nabil
Mendes Nabil
  • 46 posts
  • Paris
Posted 04 January 2017 - 12:03 PM
Hello all! How are you?
I know that "Non reflex lenses on Bolex H16 reflex" has been discussed a lot, but some people say that the "soft" issue really depends on the lens,
do you know if Zeiss Zf2 lenses (Nikon mount) will work great on a Bolex RX4 ?
These are modern lenses and i've found no information about that combination.
Will they work better than a Som Berthiot Cinor 10mm 1.9 and a Kern switar 10mm 1.6 ?
Thank you all for your answer!
#2 Mendes Nabil
Mendes Nabil
  • 46 posts
  • Paris
Posted 05 January 2017 - 11:57 AM
Hello guys!
So i asked Les Bosher and here is his answer :
"The soft image issue is caused by using non reflex lenses on a reflex camera .
Therefore you will have no problem as the adapter (the one he sells) is set correctly for the difference between the Nikon & ‘c’ mount Focal Depth.
So according to him that should work flawlessly, but i still have a question,  Zeiss ZF2 are designed for Full frame 35 , will they still be great on Standard 16mm or a Kern switar would be better?
