EXT shot in slowmo
#1 Ale Capo
Ale Capo
  • 32 posts
Posted 11 January 2017 - 01:29 AM
Hi all,
I will have an exterior shot handhelds in 120fps.
When I set higher frame rate, do I have to change the shutter speed to 1/240 ?
Furthermore, will I loose two stops of light in this shot?
My concern is whether I will notice the jump or not.
Thanks!
Alessandro
#2 Brian Drysdale
  • 5181 posts
Posted 11 January 2017 - 05:39 AM
!/240 would be the usual setting for a 120 fps shot, you could try a slower one if exposure is a issue, but you may get a too much blur/ghosting. Even so, you will be still required to open your lens aperture, remove ND or use a higher iso compared to the standard frame rate.
Edited by Brian Drysdale, 11 January 2017 - 05:40 AM.
