Beadboard - names and confusion
Beadboard poly foam core
#1 Will J. Lokken
Will J. Lokken
  • 22 posts
  • Paris
Posted 02 February 2017 - 10:01 AM
Hi guys,
I'm a big fan of using bead board as a bounce material, but sometimes it can be difficult when the gaffer in a new country doesn't know what a bead board is.
Sometimes, the material I end up with is a different, harsher material, which renders light less soft.
So, I was hoping someone in here could help me clear up my confusion between the many names,
Is there anywhere I can read and get good information about the difference between the following?
-styrofoam
-polystyrene
-- expanded polystyrene
-- extruded polystyrene
-poly (I'm guessing it is short for polystyrene)
-beadboard
-foam core
Any help would be much appreciated,
#2 JD Hartman
JD Hartman
  • 1791 posts
  • Edison, N.J. U.S.A.
Posted 02 February 2017 - 10:08 AM
Extruded Polystyrene is Depron.
http://www.depronfoa..._is_depron.html
Expanded Poly and beadboard are the same.  White one side, usually foil covered on the other, various thicknesses.  It's a type of insulating sheathing.
Foamcore
Sorry. crap-o-pedia link: https://en.wikipedia.org/wiki/Foamcore
#3 Edward Lawrence Conley III
  • 192 posts
  • Los Angeles CA
Posted 07 February 2017 - 12:32 PM
Search around Film Tools for USA terms.
http://www.filmtools...1beadboard.html
http://www.filmtools...core&page_num=2
#4 Will J. Lokken
Will J. Lokken
  • 22 posts
  • Paris
Posted 07 February 2017 - 02:02 PM
Thanks guys,
So from what I can see,
Bead board = Styrofoam Board = Expanded Poly
Depron = Extruded Polystyrene
Does that look correct?
Foam Core.. is still a bit unclear
I have some pictures, do you know which is which?
Here
#5 Edward Lawrence Conley III
  • 192 posts
  • Los Angeles CA
Posted 07 February 2017 - 02:32 PM
Those all look like  a version of the Beadboad-Styrofoam.
Foamcore is a smooth surface. It is usually used as a backing for mounting artwork, photos and anything else you need displayed.
#6 Will J. Lokken
Will J. Lokken
  • 22 posts
  • Paris
Posted 07 February 2017 - 04:57 PM
Oh no, that's even worse :)
