Tungsten to Fluorescent gel
tungsten flolights gel 241 tungstentofluorescent
#1 Petter Englund
Petter Englund
  • 18 posts
  • Sweden & USA
Posted 04 February 2017 - 09:43 AM
Hello,
Looking to buy the right gel for balancing my tungsten Blondies to match the color temperature of my daylight balanced fluorescent panels.
At first I thought I'd just gel the Blondies with a full CTB, but then I saw the 241 "Fluorescent 5700K" gel. It looks more teal than blue, I'm guessing they added a little bit of green to compensate for the green in the fluorescents.
I'm a beginner with using flo-lights, so my questions is - would I be better of with the 241 on the Blondies OR doing the full CTB on the Blondies in addition to adding a minus green to my flo-lights?
I mean, I wouldn't want that extra green in the flo-lights anyway, right?
For the second option, any experience on how strong a minus green I'd need?
And also, for those of you regularly using fluorescent panels without any other type of lights involved, do you always add a minus green (and in what strength) as a rule of thumb?
For the record: I'm not on an original Kinoflo kit, but the cheaper competitor "Flo-lights".
Thank you and have a good weekend!
  • 20254 posts
Posted 04 February 2017 - 07:28 PM
Since fluorescent tubes are all over the map in color, even daylight ones, it's hard to have a one-size-fits-all solution for gelling, it just depends on what is more efficient for the set-up.  In theory, yes, I'd correct the tungsten to regular daylight and correct the fluorescents to match, but that may not be practical in all situations.
#3 JD Hartman
JD Hartman
  • 1792 posts
  • Edison, N.J. U.S.A.
Posted 05 February 2017 - 08:26 AM
Are you using the Flo(s) with the Blondes to light an interior?   This seems too obvious of an answer, swap the daylight tubes for Tungsten and use 1/8 or 1/4 minus green as needed by eye.
