Diehard movie(1988)-to know the technique behind some shots
10 replies to this topic
#1 Mathew Collins
Mathew Collins
  • 200 posts
  • India
Posted 05 February 2017 - 08:45 PM
Could someone share your knowledge about 'Diehard' movie(1988).
1. Picture1-Gunfire
2. Picture2- There is sparkle when bullet is hitting the meta sheet.
3. Picture3- Again sparkles falls down infront of Bruce Willis who is trying to move in the tunnel due the hit of bullet.
How the Gunfire and sparkles is made?
4. Picture4-Alan Rickman's character is falling down from the building..
5. Picture5- The explosion with helicopter on top of the building.
What is the technique behind these shots?
-Collins.
Edited by Mathew Collins, 05 February 2017 - 08:46 PM.
#2 JD Hartman
JD Hartman
  • 1764 posts
  • Edison, N.J. U.S.A.
Posted 05 February 2017 - 08:54 PM
I don't think the details of pyrotechnics and their application should be discussed on this board.  If you have to ask, you haven't been trained in their safe application and you shouldn't be using them.  Hire and consult  with the appropriate specialist.
http://www.motionpic...rer.com/q10.htm
  • 1
#3 David Mullen ASC
Posted 05 February 2017 - 09:01 PM
Sparks are usually either squibs (small planted explosive packets triggered by someone) or "zirc" hits, a type of pellet fired from a special gun (usually from off-camera) that sparks when it hits a hard surface. As JD says, these things are done by trained, licensed professionals and can be dangerous.
The falling shot of Hans Gruber required a high frame rate camera shooting down at the actor falling into a large blue screen covered stunt pad, and the composited over a plate.
The explosion was done on a very large miniature.
  • 1
#4 Mathew Collins
Mathew Collins
  • 200 posts
  • India
Posted 06 February 2017 - 09:24 PM
Thank you Hartman and David.
I was just reading this link.
https://medium.com/c...6af4#.vadjhou6o
Here Greig Fraser is explaining a technique he used in 'Killing Them Softly'.
I am not able to understand it completely. I think he used LED light-strobbing to give gunfire effect.
Does someone have any information about this?
Edited by Mathew Collins, 06 February 2017 - 09:36 PM.
#5 David Mullen ASC
Posted 06 February 2017 - 11:39 PM
He created a flash using an LED strobe.
#6 Mathew Collins
Mathew Collins
  • 200 posts
  • India
Posted 08 February 2017 - 07:57 PM
Is the that effect used to create Gunfire effect?
#7 David Mullen ASC
Posted 09 February 2017 - 12:43 AM
The article isn't clear but it seems the strobe was just off-camera to create the lighting effect of a muzzle flash onto the subject.  This is not unusual, I remember reading about an old movie, maybe "The Emerald Forest", where a nighttime sequence with gunfire was mainly lit with strobe flashes.  Sometimes multiple flashes from strobes during a gun battle can make it seem like many more people are firing guns from off-camera.
#8 Phil Connolly
Phil Connolly
  • 445 posts
Posted 09 February 2017 - 04:35 AM
You can create quite realistic muzzle flash using After Effects plugins or the built in tools. But you still need flashing lights strobes or similar on set to really "sell" it. Since the muzzle flash would be illuminating the set briefly - a give away on bad cgi muzzzle flash is when the lighting on the set doesn't match up with the flash
#9 Mathew Collins
Mathew Collins
  • 200 posts
  • India
Posted 09 February 2017 - 10:54 AM
Thank you David and Phil.
#10 Edward Lawrence Conley III
  • 192 posts
  • Los Angeles CA
Posted 09 February 2017 - 04:51 PM
Strobe for in camera sell f the gunfire and FX in post for the muzzle effects
 "when Pitt pulled the trigger the strobe light duplicated the characteristic flash of light as the gun was fired (the muzzle flash itself was created in post production)."
#11 timHealy
timHealy
  • 1262 posts
Posted 10 February 2017 - 09:31 PM
I hate to date myself but it reminds me of edition of Cinefex:
http://www.cinefex.c...ues/issue36.htm
But as far as weapons are concerned it seems only props who have a special movie/tv license can rent them from weapons prop houses who also have a license. Its very regulated as it should be. I looked into it years ago when I was doing something for myself.
Weapons Specialists in NYC is one. But don't do it unless you have a professional with you who will keep everyone safe.
  • 1
