Oberkochen Opton Vario-So 2.8 10-100mm zoom APTERTURE?
#1 Chris Lange
Chris Lange
  • 61 posts
  • Minneapolis, MN
Posted 13 February 2017 - 01:13 PM
I have acquired this lens, but the aperture seems not to work.  It stays wide open when I try to change f-stop.
Is it a common flaw with this lens?  Any suggestions on how to fix.
I've attached two images of the lens.
Thank you for any help...
Chris
#2 Dom Jaeger
Dom Jaeger
  • 1816 posts
  • Melbourne, Australia
Posted 13 February 2017 - 07:52 PM
Because those zooms were designed to be used with the early auto-focus SR system, the iris uses a spring to return it to the closed position. So mechanically, the iris ring only opens the iris. If the spring is broken or weakened, or the iris mechanism is too stiff for the spring to move it, the aperture won't close down. You (or a technician) need to open the back to assess what's wrong.
#3 Chris Lange
Chris Lange
  • 61 posts
  • Minneapolis, MN
Posted 13 February 2017 - 09:01 PM
Thanks for the explanation.  I'll consider these two options.
