Canon T2I - Filming directly to solid state instead of SD card, is it possible?
Canon T2i Solid state external external hard drive
#1 Sean DelGatto
Sean DelGatto
  • 18 posts
  • Portland, Oregon
Posted 13 February 2017 - 03:34 PM
Ok, the big question I have is:
1. Can the Canon T2i possibly, as it currently is, or with a software hack, capture footage and store it to an external hard drive?
2. If it can do this, is it possible for it to film in RAW?
I'm not super excited about having to fall back to shooting on Digital, but my Film camera is being converted to ULTRA 16, and it won't be ready in time. So, I'm going to try to squeeze the best out of this little devil as possible.
Thank you for your time and input.
Sean
#2 Macks Fiiod
Macks Fiiod
  • 1666 posts
  • Og from DC, Now in NJ
Posted 13 February 2017 - 07:33 PM
I'm in leaning on the "I'd doubt it side", but even if you could manage to make that happen, the thing would overheat too quickly. It can barely handle 1080p 8bit internal as it is.
#3 David Mullen ASC
  • 20470 posts
Posted 14 February 2017 - 12:07 AM
You might want to look on the Magic Lantern site. They do have hacks for different Canon cameras and some allow for recording raw internally. There is a forum:
http://www.magiclant...ex.php?board=49.
The raw recording is pre-conversion to RGB but post pixel-binning so it's 1080P raw as far as I can tell. I don't think it can be sent to an external drive as raw since that would have to travel down an HDMI cable. And the T2i might not be one of the cameras where the hack allows for raw, you'd have to look deeper on their site.
#4 David Mullen ASC
  • 20470 posts
Posted 14 February 2017 - 12:20 AM
One post that summed up the raw capabilities wrote this:
"550D with mk11174's "ML_Mem_All_Fix2" build gives 896x512/23.976fps (video mode) or 24.000fps (photo mode) as maximum continuous shooting resolution with 16x9 aspect ratio. For widescreen, this build will also shoot 1216x416/23.976fps continuously. I had Hacked Mode on the whole time, but not sure if this has any effect at all."
So not even 1080P.
#5 Phil Rhodes
  • 12407 posts
Posted 14 February 2017 - 05:13 AM
Personally I find it slightly ridiculous that these tiny little consumer cameras can be made to do it at all.
Either way, if one is to be forced to shoot on a t2i/550D, shooting Magic Lantern raw does provide very significant improvements. I wouldn't normally cite a YouTube video as an arbiter of critical image quality, but this one does have some fairly illustrative side-by-side stuff comparing with the onboard compressed recording.
As is very clear, if you can stand the Cinemascope-esque aspect ratio, the raw is gigantically superior.
#6 Kyryll Sobolev
Kyryll Sobolev
  • 86 posts
  • Toronto
Posted 14 February 2017 - 02:17 PM
if this camera has an HDMI output, then you should be able to record to an external drive (like an atomos shogun or ninja)
not sure about recording RAW. it depends on what settings are available in the camera
#7 Phil Rhodes
  • 12407 posts
Posted 14 February 2017 - 03:10 PM
The HDMI output on older Canon DSLRs is not generally worth recording. It tends to have a lot of overlays which you can't get rid of, and sometimes odd scaling.
Raw motion picture recording is available on some cameras via the Magic Lantern third-party firmware.
#8 Freya Black
Freya Black
  • 4166 posts
Posted 14 February 2017 - 04:21 PM
but only to the memory cards and not to an external disc via HDMI or anything.
Freya
#9 Sean DelGatto
Sean DelGatto
  • 18 posts
  • Portland, Oregon
Posted 20 February 2017 - 03:06 PM
Ok, no worries. I was hoping to record out to a SSD, but that's fine. Might end up shooting on a Sony A7sii anyway.
Also tagged with one or more of these keywords: Canon T2i, Solid state, external, external hard drive
