take-up spools
#1 obie williams
obie williams
Posted 20 June 2005 - 02:54 PM
Does anyone have information on obtaining 16mm take-up spools for a K3? Also, are take-up spools universally fitted (can I use the same spools on a Bolex, Eclair, and a K3?) I'm new to the 16mm community and any info regarding this issue would be greatly appreciated.
#2 Preston Herrick
Preston Herrick
  • 89 posts
  • Washington
Posted 20 June 2005 - 03:46 PM
<{POST_SNAPBACK}>
Should be universal. Check with a lab that processes 16mm. They'll probably be happy to give them to you.
#3 Matthew Skala
Matthew Skala
  • 44 posts
Posted 21 June 2005 - 09:05 AM
As far as the K3 goes, if I remember correctly it takes daylight spools and I think you just need an empty spool, same as the one on the feed side. You should also be able to get these at any lab. I am not sure about the other camera's you mentioned but if you use daylight loads its probably much of the same.
hope this was helpful.
#4 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
  • Rochester, NY 14650-1922
Posted 21 June 2005 - 12:38 PM
<{POST_SNAPBACK}>
You are looking for a 100-foot, 16mm, R-90 spool:
http://www.kodak.com...esP.shtml#cores
#5 obie williams
obie williams
Posted 22 June 2005 - 11:14 AM
Thanks to everyone for their prompt and informed responses. I'll check some labs to see if they have some spools laying around. Also, that Kodak link tickled my synapses... lots-o-good/valuable information. Much obliged!
