Can someone please double check my math?
#1 Jay Young
Jay Young
  • 509 posts
  • Lexington KY
Posted 17 February 2017 - 06:15 PM
Shooting 800iso + 45-degree shutter = 2 stops loss
Set light meter for 24fps @ 200iso = this is what I set on the lens
Working stop of T8 should reflect that on the meter @200 iso correct?
OR, I can set the meter at 800, and subtract 2 stops.
16 on the meter = 8 on my camera.
Secondly, I should be able to key light with a 650w Tungsten Fresnel at full spot from 10' which should give about 500fc.
Then, I can use a 5K at 20' on flood to provide about 200fc, or two stops down for fill.
Does that sound about right?
  • 20254 posts
Posted 17 February 2017 - 06:41 PM
Yes, f/16 at 800 ASA is the same as f/8 at 200 ASA.
Not sure you're going to get an f/8 at 200 ASA with a tweenie at full spot from 10' away...
#3 Igor Trajkovski
Igor Trajkovski
  • 317 posts
  • Macedonia
Posted 17 February 2017 - 08:04 PM
According to ARRI Interactive Photometric Calculator:
#4 David Mullen ASC
  • 20254 posts
Posted 17 February 2017 - 08:26 PM
OK... seems to work on paper.  At least there will be a 5K on hand if you want to key with the 5K and fill with the 650w.
#5 Jay Young
Jay Young
  • 509 posts
  • Lexington KY
Posted 17 February 2017 - 08:40 PM
I laughed muchly at this. Good show!
I thought about keying with the 5k, but I would need a much less sensitive medium... I'm going to test in a day or twould and see how much I can get out of a tweeny.
