Digitizing from C-reality telecine (easy solution)
#1 Sanji Robinson
Sanji Robinson
  • 75 posts
  • International
Posted 22 February 2017 - 10:35 PM
I am looking for an easy way to digitize video (1080p) from an old Cintel C-reality telecine machine and transfer it onto a laptop. I don't own have any special equipment, just my laptop and an HDP3 SDI to DVI-D converter.
The telecine machine is hooked up to a monitor, I have attached a picture of the back.
My thinking is: I could hook up an SDI to the monitor and then go SDI to DVI with the AJA converter and then plug the DVI directly onto my Macbook Pro, but then how would I capture the input from the DVI?
Are there other ways?
Edited by Sanji Robinson, 22 February 2017 - 10:36 PM.
#2 Tyler Purcell
Tyler Purcell
  • 4251 posts
Posted 23 February 2017 - 01:01 AM
AJA VTR Xchange is an application for mac that will allow you to capture anything from the AJA card.
Though I'm unaware of any capture card that takes from DVI-D. Are you converting the DVI to HDMI?
#3 Chris Burke
Chris Burke
  • 1748 posts
  • Boston, MA
Posted 23 February 2017 - 07:32 AM
What kind of laptop? Do you have thunderbolt?? If so, get a PCI expansion chassis and then get a AJA Kona or Blackmagic Decklink card. Install capture card into expansion chassis and have at it. I would get a dual bay thunderbolt drive enclosure and stripe it. Use that for your capture drive.
#4 Chris Burke
Chris Burke
  • 1748 posts
  • Boston, MA
Posted 23 February 2017 - 07:34 AM
So you have your own C-Reality telecine?? I am jealous. How new is the tube?
#5 Robert Houllahan
Robert Houllahan
  • 1651 posts
  • Providence R.I.
Posted 23 February 2017 - 11:22 AM
1. You need to feed Tri-Level Sync to the C-Reality i.e. you will need a Tri-Level Sync generator.
2. You need a SDI capture device.
An AJA T-Tap or a BlackMagic Mini Monitor would be the two least expensive options for Thunderbolt on a Mac.
Or a USB3 UltraStudio with SDI for a PC laptop.
The SDI to DVI adapter is useless for this application.
  • 1
