Transferring HDV to 35mm
13 replies to this topic
#1 Micah Fernandez
Micah Fernandez
  • 82 posts
Posted 21 June 2005 - 09:27 PM
And what are important pitfalls to watch out for? Thanks to all who help :)
  • 20068 posts
Posted 21 June 2005 - 10:52 PM
<{POST_SNAPBACK}>
What format did you shoot? (50i/1080, 60i/1080, etc.) What camera are you using? Have you already shot the movie?
#3 Micah Fernandez
Micah Fernandez
  • 82 posts
Posted 22 June 2005 - 12:58 AM
An FX1 will be used, for a commercial that is to be shown in a movie theater. I'm not certain what format as I won't be calling the shots. Will it matter drastically?
#4 David Mullen ASC
  • 20068 posts
Posted 22 June 2005 - 01:26 AM
<{POST_SNAPBACK}>
You can transfer anything to film; it just depends on what level of motion artifacts you can live with. The FX1 only does 60i/1080; it doesn't have a 50i option like the ZU1.
For a film transfer from HDV, shooting in 50i makes the most sense, so it can be converted to 25P and then transferred 1:1 to 35mm for 24 fps projection (so an audio adjustment will be necessary.)
For transferring 60i/1080 to film, it's similar to transferring NTSC (60i/480) to film. 60 fields has to be converted to 24 frames.
Don't use the CineFrame modes for a film transfer.
Besides the non-film 60i look you're going to get, the other problem with HDV is the high compression level and low color information, which will make artifact-free color-correction in post difficult, so try and get it close to the correct look in camera when shooting.
#5 Micah Fernandez
Micah Fernandez
  • 82 posts
Posted 22 June 2005 - 10:53 AM
Thanks for the useful tips David. It's great to have someone as generous as you in this community.
Another question: what about an XL2? What are the characteristics of its image quality vis-a-vis the FX1's when blown up to 35 mm?
#6 David Mullen ASC
  • 20068 posts
Posted 22 June 2005 - 11:01 AM
You'd get the 24P motion rendition with the XL2 but a lot more resolution with the FX1.
Why not use a pro 24P/480 camera like the SDX900? 2/3" CCD's, DVCPRO-50 4:2:2, professional lenses?
#7 Micah Fernandez
Micah Fernandez
  • 82 posts
Posted 22 June 2005 - 11:10 AM
I did bring that up. However these two cameras are the only ones immediately available. The concept isn't final yet, so I'm doing as much research as I can. I take it then the XL2 would be less appropriate for a sleek, glossy look like say, a Mercedes Benz ad?
#8 David Mullen ASC
  • 20068 posts
Posted 22 June 2005 - 11:15 AM
<{POST_SNAPBACK}>
Neither an XL2 or FX1 is appropriate for a sleek ad. Car ads are shot in 35mm; the next choice would be Super-16 or pro 24P HD. Next choice would be pro 24P SD.
Somewhere below those would be a consumer camera like the XL2 or FX1. But probably the FX1 would look "slicker" than the XL2. But why mess with these cheap consumer cameras for a car commercial??? You could rent an F900 for the weekend for less than the costs of a complete DV or HDV package.
#9 Chris Burke
Chris Burke
  • 1720 posts
  • Boston, MA
Posted 22 June 2005 - 11:23 AM
<{POST_SNAPBACK}>
If this is a Mercedes add, why are you shooting on HDV and not 35mm? In any case, all the HDV cameras out there are 1/3 inch chip. the XL2 with a 35mm PS tecknik adapter and cine primes will give you a great look, the SDX 900 or Vari Cam for that matter will give you a much better, "sleeker" look. Little cameras with little chips and lenses, give a softer, low res look, akin to video. If this is desired, go for it, if not, push for a better format, even Super 16.
chris
#10 Kai.w
Kai.w
Posted 22 June 2005 - 01:50 PM
<{POST_SNAPBACK}>
Not to be pedantic (sp?) but I guess you referred to the NTSC version... The pal version does of course do 50i but lacks the 60i option, which is probably what you meant....
-k
#11 David Mullen ASC
  • 20068 posts
Posted 22 June 2005 - 07:02 PM
The PAL version is called the FX1E. The NTSC version is called the FX1. The Z1U does both 50i & 60i.
There is some good info here:
http://www.sonyhdvinfo.com/
#12 Micah Fernandez
Micah Fernandez
  • 82 posts
Posted 22 June 2005 - 07:21 PM
chris
<{POST_SNAPBACK}>
It actually isn't a Mercedes ad. The concept isn't even final yet so I am trying to get my bearings concerning what blown up DV/HDV can or cannot do, so obviously most of these questions are trite and insufferable ;) 35mm is out of the question for the budget allocated, and 16mm is extremely problematic to process in my country.
#13 Chris Burke
Chris Burke
  • 1720 posts
  • Boston, MA
Posted 23 June 2005 - 12:12 AM
<{POST_SNAPBACK}>
you may find the blow up to 35mm to be quite expensive as well. Perhaps a digital projector is in your future. Check out bonolabs.com they have some great Super 16 to hard drive packages. Good luck
#14 Kai.w
Kai.w
Posted 23 June 2005 - 02:46 PM
<{POST_SNAPBACK}>
Never noticed the "E" :rolleyes:
Thanks for clearing this up.
-k
