URGENT Arri 235 battery in LA - owner operators can you help?
#1 Davo McConville
Davo McConville
  • 30 posts
  • London, UK
Posted 14 March 2017 - 01:51 AM
Hi all!
Sorry for hijacking the forum but we have an emergency - we have a shoot tomorrow (Tuesday) - Friday and our Arri 235 batteries are dead.
Does anyone have onboard batteries or a 30v block we could rent please?
In LA!!
Many thanks
Davo
#2 Kenny N Suleimanagich
  • 902 posts
Posted 14 March 2017 - 11:15 AM
Keslow camera should have the on-board Anton Bauer mount. Otherwise you can use an Anton Bauer 12/28 belt
#3 Todd Anderson
Todd Anderson
  • 99 posts
Posted 15 March 2017 - 02:45 PM
If anyone knows of a place that has specifically re-celled the factory Arri 235 on-board batteries successfully, I would love to know. I've heard a few varying stories that range from, "no problem", to "the battery packs are kind of glued in there a bit and you have to scrap off all this excess glue and that makes them a bit more difficult". Thanks in advance.
#4 Davo McConville
Davo McConville
  • 30 posts
  • London, UK
Posted 15 March 2017 - 02:58 PM
Thanks Kenny!
I tried but in the end we rebuilt them ourselves.
Todd – it takes a minute but it's not hard.
22 Standard AA NimH cells - 1.2A, Mah 1700-2100 – flat top / solder tabs
Reuse the thermistors etc from inside the battery (not hard to disassemble) and rebuild based on what you see in there.
You'll probably need to score the tops of the batteries to make sure the solder sticks (the Arri cells are electro soldered).
Every single battery needs a tab top and bottom.
They've then glued the block together, but regular glue gun glue won't be heat resistant enough to replace it with.
We recelled 4 batteries in about 5 hours.
