Suggestions for sound absorptive fabrics "socks" for Arri SR2
10 replies to this topic
#1 Eric F Adams
Eric F Adams
  • 48 posts
  • Baton Rouge, Louisiana
Posted 31 March 2017 - 06:58 PM
Besides using a towel.  Is there something good to use to cover the camera to muffle out the little clicking motor sound?  Fits good and no problems or interfering the workings of the camera.  Thanks.
#2 George Ebersole
George Ebersole
  • 1679 posts
  • San Francisco Bay Area
Posted 31 March 2017 - 09:03 PM
A blimp.  Back in the day they ran around 30grand depending on the camera.  What kind of camera do you have?
#3 Eric F Adams
Eric F Adams
  • 48 posts
Posted 31 March 2017 - 09:40 PM
Arriflex SR2
#4 George Ebersole
George Ebersole
  • 1679 posts
Posted 01 April 2017 - 11:56 AM
Hmm, that's odd.  That particular camera should run silently.  You might want to have a tech at the local rental house check it out.
#5 Phil Rhodes
  • 12407 posts
Posted 01 April 2017 - 12:03 PM
I've shot with the SR2 and had absolutely no problem. As with almost any film camera there's a very faint purring, inevitably, but if it's causing really serious problems, as George says, it's fault. That could be causing damage, so get it looked at.
You could, I suppose, in the most extreme circumstances, homebrew a blimp. The trick, as I understand it, is layers of harder and softer materials. I once made a very effective sound-deadening enclosure (for something other than a camera) out of some layers of vinyl flooring and upholstery foam, with the flooring serving as a hard reflective surface and the foam catching and absorbing the reflections. Effectiveness is limited by your tolerance for size, and on a camera, the need to have the viewfinder and lens, which will carry some vibration and thus sound, sticking out.
#6 Adrian Sierkowski
  • 7516 posts
Posted 01 April 2017 - 01:00 PM
As mentioned SR2/3 should be very very quiet when within spec--- as in quieter than even some digital cameras with fan noise. Get it serviced, and perhaps check how well it's loaded-- could be a bit of film just scratching inside the mag.
#7 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 01 April 2017 - 01:06 PM
Could be the film loop size too, as I seem to recall that made some difference in film transport noise. Maybe try a loop one perf smaller.
Worst case, there are barneys made for the SR cameras. Like old leather football helmets, they are. Though from what I understand, most of the noise generated is actually coming out of the lens port, which a barney won't help with.
#8 Eric F Adams
Eric F Adams
  • 48 posts
Posted 02 April 2017 - 10:32 AM
 Hey George.  Silent, it's not..  It has the normal purr of the ole Arri film.  I guess I need to do a better job of my camera position in relation to my sound.
Thanks Phil.  I get it serviced with Bernie up in New York.  I am purchasing some Producer Choice sound blankets so that should help.
Thanks Adrian.  I will get it checked out.
Interesting you say that Satsuki.  I have notice a difference in my film loop size.  I purchase an additional mag for my next project so now i will have 3 mags.  Now i can take my time and load them up just right instead of hurrying to load on set...lol.
#9 Adrian Sierkowski
  • 7516 posts
Posted 02 April 2017 - 12:31 PM
Shouldn't take more than a minute to load/unload a mag lol.
On the SR3 at least when i'd load i'd make the loop tight to the marked line with no extra slop in it.
#10 Eric F Adams
Eric F Adams
  • 48 posts
Posted 03 April 2017 - 06:31 PM
A minute?  goodness.  Now I can unload in about 2 minutes or less, but to load...I need full concentration and I take my time.  I would say I average 4 to 5 minutes.
#11 Robin R Probyn
Robin R Probyn
  • 2622 posts
  • Tokyo
Posted 03 April 2017 - 06:47 PM
Try an optical flat filter too.. some noise is coming out the front of the lens too... as an assistant I remember some SR,,s could be pretty noisy compared to an Aaton..  usually around the gears/cogs that drives the mags.. you could get a clunking sound if they were worn .. other than that just get a blimp .. not a bad idea to have one anyway..
Edited by Robin R Probyn, 03 April 2017 - 06:48 PM.
