Help Identifying Scoopic Connector
Scoopic battery power canon grey Scoopic
7 replies to this topic
#1 Adam Fox-Long
Adam Fox-Long
  • 4 posts
  • Lansing
Posted 08 April 2017 - 06:06 PM
Does anyone know what the external battery connector on the grey canon Scoopic is called or where I could find one? It has 4 pins but it's clearly not XLR
#2 Jean-Louis Seguin
Jean-Louis Seguin
  • 748 posts
  • Montreal, Canada
Posted 08 April 2017 - 08:28 PM
If you're referring to the original Scoopic 16, it's a Hirose connector part number RM12WBP-4S(71).
Digikey has it as part number HR1793-ND. The cable clamp is sold separately.
#3 Adam Fox-Long
Adam Fox-Long
  • 4 posts
  • Lansing
Posted 08 April 2017 - 09:44 PM
Thanks so much! You wouldn't happen to know the part number for the clamp? I can't seem to find the right one. I'm very new to this
Edited by Adam Fox-Long, 08 April 2017 - 09:53 PM.
#4 Jean-Louis Seguin
Jean-Louis Seguin
  • 748 posts
  • Montreal, Canada
Posted 08 April 2017 - 09:54 PM
https://www.digikey....1783-ND/1125584
I think it's at the bottom of the page.
#5 Adam Fox-Long
Adam Fox-Long
  • 4 posts
  • Lansing
Posted 08 April 2017 - 10:02 PM
Once again, thank you! So now the trick would be connecting it to a cable and power source. Is it as easy as just removing whatever the connection is on the external pack and replacing it with this one?
#6 Jean-Louis Seguin
Jean-Louis Seguin
  • 748 posts
  • Montreal, Canada
Posted 09 April 2017 - 11:29 AM
The cable clamp is available in 4 types accordong to the diameter in millimeters of the cable used.
Hirose # RM12WBP-CP(x)(71)
Replace x with either 4, 5, 6 or 7
Digikey # HR1800-ND thru HR1804-ND
Refer to catalog page 429
As for the connector on the battery pack side, 4pin XLR (male) is the standard.
Edited by Jean-Louis Seguin, 09 April 2017 - 11:36 AM.
#7 Gregg MacPherson
Gregg MacPherson
  • 1925 posts
  • New Zealand
Posted 09 April 2017 - 06:07 PM
Hey, Jean-Louis,
Can I tap your encyclopedic lore and ask what is the spec for the stepped 2 pin connector for the ACL ergonomic handgrip.  I'll put a separate thread on it so that the categorisation makes it easy to find for others later..
Cheers,
Gregg (Gregoire).
#8 Jean-Louis Seguin
Jean-Louis Seguin
  • 748 posts
  • Montreal, Canada
Posted 09 April 2017 - 06:57 PM
I'm not 100% sure but I think it's a very early LEMO connector. I can look it up.
Also tagged with one or more of these keywords: Scoopic, battery, power, canon, grey Scoopic
