Arri SR2- Working?
41 replies to this topic
#1 Scott Pickering
Scott Pickering
  • 171 posts
Posted 09 April 2017 - 06:20 PM
I bought an Arri SR2 that wasn't tested. It came with a magazine. That said I hooked it up to a Bescor 12V battery. Nothing happened. I can't seem to be able to get the unit to turn on or show its getting power. Not sure how to get it to run either. Do I need the adapter piece that sets the frame rate to 24? Or will it run without it? I'm currently trying to sell the package, and would be able to sell it if I could get it running. Any help here? Look on Ebay for the SR2 package I'm selling to see pics.
#2 Scott Pickering
Scott Pickering
  • 171 posts
Posted 09 April 2017 - 06:40 PM
Item #172609365368 if that helps.
#3 Gregg MacPherson
Gregg MacPherson
  • 1993 posts
  • New Zealand
Posted 09 April 2017 - 09:02 PM
That number didn't take me there. What about just using the URL..?
#4 Bill DiPietra
Bill DiPietra
  • 2339 posts
  • New York City
Posted 09 April 2017 - 10:56 PM
Gregg - try this link...
http://www.ebay.com/...wsAAOSwmgJY4tNM
#5 Bill DiPietra
Bill DiPietra
  • 2339 posts
  • New York City
Posted 09 April 2017 - 11:15 PM
Scott, I assume you were attaching the XLR cable in to the rear of the camera?...
#6 Scott Pickering
Scott Pickering
  • 171 posts
Posted 10 April 2017 - 07:50 PM
"XLR cable to back of camera."
Yes. Forgive me, but I've never operated an Arri before.
Edited by Scott Pickering, 10 April 2017 - 07:52 PM.
#7 Tyler Purcell
Tyler Purcell
  • 4389 posts
Posted 11 April 2017 - 01:56 AM
Well, first thing is that SR's are 24v systems, not 12v systems. IDK how they'd react to 12v, never tried.
Second, if you supply a good/measured 24v signal to the camera and it still doesn't work, check the fuse. It's on the flat piece where the magazine goes (the electronics). It's the little circular port, sometimes plastic see-through. Measure the fuse to make sure it's in good working order.
#8 Gregg MacPherson
Gregg MacPherson
  • 1993 posts
  • New Zealand
Posted 11 April 2017 - 02:32 AM
I thought the standard batteries for SRIIs were 12V.
#9 Dom Jaeger
Dom Jaeger
  • 1894 posts
  • Melbourne, Australia
Posted 11 April 2017 - 03:46 AM
SR1 and 2 cameras run off 12V.
Did you already have a 4 pin XLR power cable or have you wired it yourself? Have you got the polarity and pin wiring right? Pin 1 should be ground, pin 4 +12V
#10 aapo lettinen
aapo lettinen
  • 1200 posts
  • Finland
Posted 11 April 2017 - 04:44 AM
yep the SR1 and 2 are 12v and the SR3 is 24v.
as Tyler said the fuse is the first thing to check if these cameras don't run. though do the polarity check first if it's a diy cable
#11 Scott Pickering
Scott Pickering
  • 171 posts
Posted 11 April 2017 - 07:23 PM
Not a do it yourself cable. Stock cable for the Bescor battery. 12V. Battery was charged.
#12 Scott Pickering
Scott Pickering
  • 171 posts
Posted 15 April 2017 - 09:27 PM
I have noticed this camera uses a speed controller unit. Is this piece necessary to use the camera or even turn it on? It might be why I can't get mine to do anything. Any info?
#13 Dom Jaeger
Dom Jaeger
  • 1894 posts
Posted 15 April 2017 - 10:28 PM
No it shouldn't need the speed control to run.
Have you checked the fuse? Voltage polarity is correct?
#14 Scott Pickering
Scott Pickering
  • 171 posts
Posted 16 April 2017 - 01:14 AM
I'm not sure what the polarity of the pins is supposed to be to be honest. The cable was original with the battery. What kind of fuse does it use?
#15 Nojus Drasutis
Nojus Drasutis
  • 68 posts
  • Lithuania
Posted 16 April 2017 - 02:17 AM
Hi, Scott,
For correct polarity, check sr 2 manual: http://www.doc-cba.b...6SR2_manual.pdf
I'm writing from my phone so i cannot chek if it's really there but there should be a scheme for all the wires, plugs, connectors. In the manual you should also find info about fuse.
Happy easter, by the way!
Nojus
#16 Mark Dunn
Mark Dunn
  • 2873 posts
Posted 16 April 2017 - 05:15 AM
They look like axial lead fuses. As long as the dimensions are similar just match the rating. They're not expensive. Of course you'll test the existing ones with a meter.
Dom told you the polarity, pin 1 ground, pin 4 12V.
#17 Scott Pickering
Scott Pickering
  • 171 posts
Posted 16 April 2017 - 05:04 PM
Found the two selections on the base of the camera. It looks like its set to 24 fps at 60hz. Fuses I can't find my tester, so not sure if they are good. One is .75 amps and the other 10 amps. What is the voltage on those fuses? Manual doesn't state that info. They are pretty small fuses, so not sure who would be best to order them from.
#18 Scott Pickering
Scott Pickering
  • 171 posts
Posted 18 May 2017 - 11:57 PM
Well I sent the entire package to Bernie at Super 16. He told me the battery was toast, so no wonder the camera didn't power on. Also the mechanism was dry and needed lubing. I had him go over the camera to clean and lube it up and also go over 1 of the 2 magazines. Lens was collimated. I now have the package up for sale.
#19 tom lombard
tom lombard
  • 166 posts
  • nebraska
Posted 19 May 2017 - 08:30 AM
Is that standard 16 or super?  I may be interested.  Feel free to PM me.
#20 Scott Pickering
Scott Pickering
  • 171 posts
Posted 19 May 2017 - 10:52 PM
PM sent Tom. Its standard 16mm
