How to add Depth and Dimension in the frame
blocking lighting
9 replies to this topic
#1 Carlos Herrera
Carlos Herrera
  • 29 posts
  • Editor
  • San Diego - Los Angeles
Posted 10 April 2017 - 01:52 PM
Hi everyone!
I'm going to be making a movie with my friends soon (Horror/Comedy). This may be a broad question, but here it is.
In your opinion, what Cinematography techniques add dimension and depth in an image?
With this movie, I am hoping to immerse the audience by creating a visually immersive and interesting "mise en scène".
I have been leaning towards good blocking, but I would love to hear how you all feel this is accomplished.
Thank you!
  • 20471 posts
Posted 10 April 2017 - 02:37 PM
Obviously having deeper backgrounds can help, as opposed to staging things against a flat, blank wall...
Framing dark against bright against dark, etc. creates a feeling of depth. There is a notion that bright areas advance, dark areas recede (though this is not a hard and fast rule) so having faces against a darker background tends to make them stand out more.
  • 2
#3 Carlos Herrera
Carlos Herrera
  • 29 posts
  • Editor
Posted 10 April 2017 - 03:01 PM
Thank you for your suggestions Mr.Mullen!
I will practice some compositions with your advice in mind.
#4 AJ Young
AJ Young
  • 198 posts
Posted 12 April 2017 - 01:30 PM
Lens choice is another factor to consider. Wider lenses give a better sense of space when the subjects move forward and back from the camera as opposed to longer lenses that feel images feel compressed.
I recommend getting this book: The Visual Story by Bruce Block. LINK
  • 1
#5 Carlos Herrera
Carlos Herrera
  • 29 posts
  • Editor
Posted 12 April 2017 - 04:16 PM
Thanks for the tip! I'll try some experimenting with wide angle lenses per your advice!
#6 Timothy Sewell
Timothy Sewell
  • 9 posts
  • Hove
Posted 13 April 2017 - 07:54 AM
Haze can add depth.
  • 1
#7 Carlos Herrera
Carlos Herrera
  • 29 posts
  • Editor
Posted 13 April 2017 - 11:41 AM
Haze can add depth.
Other than fog machines, how can you create haze?
#8 David Mullen ASC
  • 20471 posts
Posted 13 April 2017 - 12:29 PM
Haze machines... there really isn't a substitute for haze other than steam, but tends to work better in a jungle set, not an interior (unless a steam room) but then you have to deal with your lenses fogging up.
Anything else that hangs in the air is probably not safe to breathe for very long.
#9 David Mullen ASC
  • 20471 posts
Posted 13 April 2017 - 12:31 PM
Haze can sometimes have the opposite effect of adding depth, it can flatten the image by washing out the background.
#10 Carlos Herrera
Carlos Herrera
  • 29 posts
  • Editor
Posted 13 April 2017 - 01:16 PM
Thank you for your insights Mr.Mullen, the use of haze makes more sense to me now. I'll do some additional research as well.
