"cheap way to do a " Overhead shot
#1 AlejandroGomez
AlejandroGomez
  • 56 posts
  • 2nd Assistant Camera
  • Germany
Posted 18 April 2017 - 09:35 AM
Hi Guys
Really need help on this. First of all I have no idea of gripping so thats why I need a good advice.
We need to do a POV. Its a Overhead shot with a Epic Mysterium and a 24mm. The camera needs to tilt down looking to the floor where it will be a pair of shoes, we will throw things at the shoes, like paint, dirt, water...
I need advice on how to rig the camera on a safe way, Im gonna make the camera really light, just a photo lens and power up though a DC power Cable, without V-mounts. The camera should be arround 1,70 and 1,80m higher.
Any ideas on how to do it? Needs to be really simple and cheap. No Jib, No slider...
Thank you in advance
#2 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 18 April 2017 - 10:33 AM
Does the camera need to tilt down in shot? Or can it be locked off?
Ideally, you would make a goalpost rig of some kind so that there is no tripod or stand underneath the camera. That could be something like a long speedrail pipe with a right-angle cheese plate in the middle, and two combo stands on the ends. It would help to have a few 3/8-16 mounting points on the camera body so you can stabilize it
But if that's still too complex, then I suppose you could do it with a tripod and a false floor to hide the tripod legs. Get four apple boxes and a thick sheet of plywood. Dress the plywood to look like the floor and either have the actor stand on the surface, or if you can get away with prop legs and shoes use that instead. That will simplify camera positioning and you can have the camera lower without having to work around the actor's body.
  • 1
#3 Brenton Lee
Brenton Lee
  • 137 posts
  • Melbourne, Australia
Posted 23 April 2017 - 06:27 AM
Extend your fluid head / tripod out, cantilever it off the right height ladder then use a bit of accessory cord to manipulate the fluid head up or down.
Just make sure you sandbag the ladder.
  • 1
#4 Hannes Famira
Hannes Famira
  • 5 posts
  • New York City
Posted 10 December 2017 - 12:57 PM
clamp a wooden plank to any of the steps of a ladder, put your fluid head on the protruding side and put this on top of your fluid head: http://a.co/jjOzGQk
#5 David Mullen ASC
  • 20175 posts
Posted 10 December 2017 - 02:16 PM
Two ladders and a plank?
  • 1
#6 Tony Burns
Tony Burns
  • Wilmington, Delaware
Posted 24 May 2018 - 06:11 PM
I don't typically work with speedrail and I don't own any combo stands, but I do have an Avenger D600 boom that works great for this kind of shot between a couple of c-stands, with the stud on the end of boom put into the grip head on the opposite stand. In the middle I'll clamp a mafer with a Manfrotto 208HEX plate and a small fluid head.
