Arri SR-3 Power Draw
#1 Toto D Guerra
Toto D Guerra
  • 8 posts
Posted 23 April 2017 - 01:48 AM
I wanted to share the following measurements I did on my SR-3 camera package. Might come handy when you're trying to determine your battery needs and expected turnaround on set, and/or for those who have battery recell projects like me currently.
. Idle: 0.09A
. Idle + IVS: 0.40A
. 24fps: 0.35A
. 24fps + IVS: 0.67A
. 75fps: 0.65A
. 75fps + IVS: 1.01A (2.00A peak charge at start)
. Idle + RCU-1: 0.12A
. 24fps + RCU-1: 0.38A
. 24fps + IVS + RCU-1: 0.72A
. 75fps + IVS + RCU-1: 1.05A
Best,
Toto
  • 2
#2 Dom Jaeger
Dom Jaeger
  • 1789 posts
  • Melbourne, Australia
Posted 23 April 2017 - 03:54 AM
Hi Toto,
Thanks for taking the time to post your measurements!
Can I ask if you measured the current draw with a loaded mag, an empty mag or just the body? It makes a little bit of difference I've found. My (possibly faulty) memory of SR3 specs is a draw of about half an amp with a 400' load at 24fps.
A simple way to remember the accessory draw is that an IVS basically draws about a third of an amp regardless of camera settings, while an RCU unit pretty much draws nothing.
  • 2
#3 Toto D Guerra
Toto D Guerra
  • 8 posts
Posted 24 April 2017 - 04:26 AM
Hi and thanks for your response,
I did the measurements with an attached empty mag. The measurements would be different with actual film in there and thank you for asking for clarification. I might find expired film and redo the tests then, I'll update this post when I do so.
