CTO conversion
#1 Mathew Collins
Mathew Collins
  • 202 posts
  • India
Posted 24 April 2017 - 02:07 AM
Lee portal says,
Full CTO    Converts Daylight to Tungsten Light    6500K to 3200K
1/2 CTO    Converts Daylight to Tungsten Light    6500K to 3800K
1/4 CTO    Converts Daylight to Tungsten Light    6500K to 4600K
1/8 CTO    Converts Daylight to Tungsten Light    6500K to 5550K
3/4 CTO    Converts Daylight to Tungsten Light    6500K to 3600K
http://www.leefilter...lter=conversion
What would be the change in CT when we use these filters in front of a light with 5600K( say Arri PAR 4K)
Please share your views.
#2 Michael Rodin
Michael Rodin
  • 265 posts
  • Moscow
Posted 24 April 2017 - 07:47 AM
Your HMI's color temp will be roughly 180 mired (= 1 000 000 / Kelvin CT). Then you find out the mired shift of a certain CTO and add it. Or subtract if it's CTB.
More mired - less Kelvin - warmer
Less mired - more Kelvin - colder
#3 Mark Dunn
Mark Dunn
  • 2784 posts
Posted 24 April 2017 - 08:03 AM
Full CTO mired shift is about 159. So the new CT will be 1000000/(180+159)=2950K.
There's a chart on page 56 of the "Think Lee" download on that site under "resources". Just put a ruler across it.
http://www.leefilter...-resources.html
Edited by Mark Dunn, 24 April 2017 - 08:07 AM.
  • 1
#4 Mathew Collins
Mathew Collins
  • 202 posts
  • India
Posted 25 April 2017 - 10:52 PM
Thanks much Mark and Michael.
When I calculated the required Miredshift, for converting 5600K to 3200K using the formula,
1000000/3200 -  1000000/5600 =133
1000000/3200=312.5
1000000/5600=178.5714285714286
I could not find a filter with 133 Miredshift in the pdf. But almost near one is 285 (Three Quarter CTO) with a value +124.
Would this calculation is correct?
#5 David Mullen ASC
  • 20191 posts
Posted 26 April 2017 - 12:26 AM
626 LED conversion gel (Seven Eighths Digital LED CTO) has a 132 MIRED shift value.
#6 Michael Rodin
Michael Rodin
  • 265 posts
  • Moscow
Posted 26 April 2017 - 08:45 AM
If you can't get it with one filter, use two. Or more. And if you want to apply a lot of correction to a big light (especially a PAR) it's better to add a couple spaced gel frames than a single dense gel.
The so-called LED gels shift tint, not only color temp. They're for daylight LEDs only, on HMIs they can give magenta color casts.
#7 Mathew Collins
Mathew Collins
  • 202 posts
  • India
Posted 26 April 2017 - 12:06 PM
Would the LED conversion gel is OK for HMI PARs?
#8 Stuart Brereton
Stuart Brereton
  • 3395 posts
Posted 26 April 2017 - 01:40 PM
There's no need to get hung up on correcting your lamps exactly according to the Mired system. Most people do perfectly well with Full, 1/2 and 1/4 CTO and Full ,1/2 and 1/4 CTB
#9 Mathew Collins
Mathew Collins
  • 202 posts
  • India
Posted 27 April 2017 - 09:30 AM
Hi Stuart,
Thanks much. Now I got the answer.
