Litemat s4 hard case options?
#1 David Schuurman
David Schuurman
  • 47 posts
Posted 03 May 2017 - 01:04 PM
Hey folks, I'm pulling the trigger on a litemat s4 and I'm wondering if anyone has encountered a solution to transporting it in a hard case for air travel? It seems there is not much option other than to custom build something but hopefully someone out there has encountered this roadblock and solved it.
Thanks!
#2 JD Hartman
JD Hartman
  • 1809 posts
  • Edison, N.J. U.S.A.
Posted 03 May 2017 - 05:18 PM
Are you saying you don't trust the baggage handlers to give your equipment the care and respect it deserves??
I'd look at archery cases.  I'm sure you can find a hard bow case that will fit the Litemat and all the accessories.  Might require a little custom foam work to keep the battery packs restrained and secured.
