zoom lens not zooming in (red pl zoom 17-50mmv2)
#1 dio zafi
dio zafi
  • 33 posts
  • london
Posted 05 May 2017 - 02:47 PM
I'm on a job with a red pro zoom lens 17-50mmv2 that is not zooming in?
Anyway we can fix this on the set?
#2 David Hessel
David Hessel
  • 171 posts
Posted 05 May 2017 - 10:00 PM
No I doubt it, something is seriously wrong if it won't zoom. If you are lucky maybe it is a single loose or missing screw that is causing the focus housing to not engage the internal mechanics. I am not familiar with the red zoom so cannot say for sure. Even so finding a replacement would be challenging on short notice.
  • 1
#3 dio zafi
dio zafi
  • 33 posts
  • london
Posted 07 May 2017 - 07:34 AM
everything is else is working on this zoom...and you can zoom out...you just can't zoom in????
#4 Dom Jaeger
Dom Jaeger
  • 1784 posts
  • Melbourne, Australia
Posted 07 May 2017 - 10:12 AM
If you can't zoom in, how do you know you can still zoom out? Aren't you stuck at 17mm? Or can you manually pull it out?
It's usually something like a loose screw or a broken follower that jams the zoom in a lens like this, you'd need to pull it apart to find out. Probably best to rent another lens if you don't have a competent tech.
  • 1
#5 dio zafi
dio zafi
  • 33 posts
  • london
Posted 08 May 2017 - 12:09 PM
do you think we should send this into Red for repair or a regular camera repair shop?
#6 Dom Jaeger
Dom Jaeger
  • 1784 posts
Posted 09 May 2017 - 07:47 AM
A good repair shop should be able to fix it.
Having said that, as a lens repairer I haven't had good experiences with Red in terms of getting parts for their lenses, so if something needs replacing it could be a hassle. But parts can be manufactured or modified from other parts. Chances are it's just something loose anyway.
I don't know if Red have a repair facility in the UK, they told me here in Australia that I had to send their lenses back to the States. I told them to go jump and did the repairs locally without a problem. Sending something halfway around the world just to tighten a screw seems ludicrous to me.
#7 dio zafi
dio zafi
  • 33 posts
  • london
Posted 27 May 2017 - 02:19 PM
here's our update ...the track that the zoom moves is chipped...a piece was broken off...(probably someone forced the zoom)  now where to get the part is the question..I will try to post photos..thanks.
