Two camera setup
#1 Rich Hibner
Rich Hibner
  • 121 posts
Posted 06 May 2017 - 03:22 PM
I have a quick question re: two cam setup. I have two black magic micros with sporting a speedbooster and a Sigma 18-35 and the other with a regular nikon mount and a Sigma 50-100. When shooting, which would you suggest: Having two cams on the same side capturing one actor - a mid and cu, or have the each cam setup on opposites to get both actors at the same time - a close up on one and a mid on the other?
How would you go about doing it? Any suggestions?
#2 Adrian Sierkowski
  • 7480 posts
Posted 06 May 2017 - 11:09 PM
I tend to like both on one side and the longer lens camera closer to the eye-line. But it depends on the space, i've crossed lenses before of course as well.
#3 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 07 May 2017 - 01:18 AM
I think it depends on the circumstances.
Do Medium/CU on the same actor if you're trying to maximize continuity between shots or if you only have the actor for a limited time and need to finish as much of their coverage as possible.
For example, if you have one expensive actor in the cast and need to shoot them out as fast as possible. Or if you have a complicated gag that requires a lot of reset time like blood spatter or wardrobe/makeup changes. It saves time to grab two shots on the shot list at once. This is usually easier for lighting and camera, but worse for sound since they would usually like to get their boom mic closer for a CU, but you will see it in the Medium.
Do opposing shots if you need to capture both actors' performances as they riff off of each other or improvise. Or if there are ego issues with one actor getting their coverage first. Think of the diner scene in 'Heat' with Robert DeNiro and Al Pacino on-screen together for the first time. It makes sense to shoot both angles simultaneously. This is usually more limiting for camera and lighting, but easier on sound (as long as there are multiple boom operators).
#4 David Peterson
David Peterson
  • 245 posts
  • Auckland, New Zealand.
Posted 11 May 2017 - 11:29 AM
Be careful with how you do multi cam shoots.... unless you want your soundie to murder you in your sleep! ;-)
