Arricam LT
arricam arricam lt arricam st magazines 1000ft gripping jib
#1 Kaspar Kamu
Kaspar Kamu
  • 26 posts
  • Berlin, Germany.
Posted 07 May 2017 - 07:25 AM
Dear all,
I'm shooting a short film next month with an Arricam LT. Our number of mags are limited, so we will go with 1000' rolls. On the ST I've seen that the magazines can be mounted on top of the camera. My question is whether it's possible to do this with the LT as well.
We need to do this, since many shots will be on a jib, and if the magazine is mounted to the rear, it will undoubtedly knock against the jib if we're in a steep low-angle.
Alternatively (and this might be a question better suited to a gripping subforum) is there a way of extending the jib to avoid the aforementioned problem? '
Many thanks in advance!
#2 Dom Jaeger
Dom Jaeger
  • 1788 posts
  • Melbourne, Australia
Posted 07 May 2017 - 10:00 AM
If you check out the various quick guides online such as:
http://cinematograph...cam lite_qg.pdf
or
http://www.arrirenta...systemguide.pdf
you can see there is an adapter that allows you to use studio mags on an Arricam LT at a slightly elevated and angled position, but there is no facility to mount a mag directly on top.
#3 Kaspar Kamu
Kaspar Kamu
  • 26 posts
  • Berlin, Germany.
Posted 07 May 2017 - 05:35 PM
or
Thanks for your reply.
Do you know if this would still work on a jib arm?
#4 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 08 May 2017 - 03:59 AM
Depending on the jib, you may be able to undersling the camera which could solve the problem. Long cameras are not usually a problem for something like a Jimmy Jib. Most broadcast and Alexa/zoom lens rigs are longer and work fine.
Also tagged with one or more of these keywords: arricam, arricam lt, arricam st, magazines, 1000ft, gripping, jib
