Sony F55 + Ronin
documentary shooting sony f55
#1 Matias Nicolas
Matias Nicolas
  • 190 posts
  • Buenos Aires, Argentina
Posted 17 May 2017 - 03:35 AM
Does the DJI Ronin supports a Sony F55 camera, with a Compact Prime lense and a ffocus wireless? Which recommendation can you give me?
#2 aapo lettinen
aapo lettinen
  • 1159 posts
  • Finland
Posted 17 May 2017 - 07:40 AM
our dp uses the ronin with f5 and raw recorder. should work ok if you balance it correctly (may need additional weights to shift the balance) and you will need to have the extension kit for ronin
#3 Robin R Probyn
Robin R Probyn
  • 2352 posts
  • Tokyo
Posted 17 May 2017 - 08:39 AM
AFAIK..F55 cant be powered from the ronin batts... F5 is ok.. but 55 power draws too much..  you need the XL arms .. its really heavy, so pretty much need the easy rig with the extended arm..  popular opinion seems to be your better off with a A7 or RED.. Alexa mini etc.. F55 is just too big..and heavy..
I would definitely check it out first before buying one/ hoping to use one on a shoot with little prep time..
Edited by Robin R Probyn, 17 May 2017 - 08:41 AM.
#4 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 17 May 2017 - 02:44 PM
You can lose the battery from the camera if you put a battery plate on the Ronin crossbar. Then you can power the F55 with a right angle XLR4 to d-tap cable.
But as Robin says, the camera is not an ideal fit for the Ronin, especially if you're adding the R5 Raw module. And the XL arms generally make it more difficult to balance, not really worth it in my opinion. The Movi M15 would be better.
A nice lightweight remote follow focus for gimbal use is the Heden Carat with M26VE motor. The MDR is tiny.
#5 Matias Nicolas
Matias Nicolas
  • 190 posts
Posted 19 May 2017 - 03:02 AM
ok! well, I will try to loose weight as much as I can. Thanks!
#6 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 19 May 2017 - 05:03 PM
The main thing is the shorten the camera as much as possible to avoid having to use the extension arms. The v-mount battery and the raw module make it longer.
