Replicating the look of color Nitrate prints
11 replies to this topic
#1 Sanji Robinson
Sanji Robinson
  • 41 posts
  • The World
Posted 20 May 2017 - 02:10 PM
Color nitrate prints are gorgeous: the shimmer, contrast, deep blacks and vivid color. Especially IB technicolor nitrate prints.
I understand that nitrate film stock has higher silver content than safety film.
Is there any way of getting close to that with standard 35mm safety film?
  • 19832 posts
Posted 20 May 2017 - 06:29 PM
There is no silver in a color print unless a silver retention process like ENR is applied and that would only be done to regular color print stock.
Nitrate color prints are almost exclusively Technicolor dye transfer prints though I guess there were some early Eastmancolor print stock on a nitrate base though I don't know for sure without a search.
#3 Sanji Robinson
Sanji Robinson
  • 41 posts
  • The World
Posted 20 May 2017 - 06:43 PM
If I were to leave the silver in the print, would the image shimmer when projected like Nitrate film?
#4 David Mullen ASC
  • 19832 posts
Posted 20 May 2017 - 06:48 PM
Are you too young to have seen an ENR or skip bleach print? So many movies in the 1980s through mid 2000s did that.
#5 Sanji Robinson
Sanji Robinson
  • 41 posts
  • The World
Posted 20 May 2017 - 07:13 PM
I have heard of it but I don't remember. Is it beautiful? Does it closely resemble a nitrate print?
#6 Dirk DeJonghe
Dirk DeJonghe
  • 609 posts
  • Kortrijk,Belgium
Posted 21 May 2017 - 12:44 AM
Nitrate is the base, just like acetate or polyester. it has no relationship to the look of the emulsion. We still use B&W acetate and polyester base stocks daily. if processed to the same gamma, there is no difference. Nitrate is no longer manufactured since the 1950s because of flammability. 16 and 8mm never were on nitrate base because of intended amateur use.
#7 Dan Hasson
Dan Hasson
  • 69 posts
  • London, England
Posted 21 May 2017 - 04:26 AM
This is so right.
Also Sanji, there is so much more going into making an image 'gorgeous' than the medium it was shot and/or projected on.
#8 Sanji Robinson
Sanji Robinson
  • 41 posts
  • The World
Posted 21 May 2017 - 06:26 AM
This is so right.
true.
but what is it that gives nitrate film its shimmer and beauty? if its only the amount of silver, would it not be similar to the enr?
#9 David Mullen ASC
  • 19832 posts
Posted 21 May 2017 - 09:29 AM
Your first post was about Technicolor I.B. prints on nitrate base, which as I said, don't have silver in them, so now are you talking about b&w nitrate prints?
#10 Sanji Robinson
Sanji Robinson
  • 41 posts
  • The World
Posted 21 May 2017 - 09:39 AM
no i still mean technicolor ib on nitrate base. do you know what it is that make technicolor ib on nitrate sparkle on the screen as opposed to technicolor ib on safety film?
can you describe what enr prints look like? other than more contrast and desat color, is there something special about them?
#11 David Mullen ASC
  • 19832 posts
Posted 21 May 2017 - 12:01 PM
I.B. Technicolor prints on nitrate base went away around the same time as shooting on 3-strip Technicolor cameras so you may be missing the look of 3-strip color rendition compared to Eastmancolor negative as opposed to how they looked printed on nitrate versus safety base. Base is clear stock so it shouldn't be contributing much of anything to the look.
#12 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 21 May 2017 - 04:51 PM
I would describe an ENR print as looking completely opposite to a Technicolor IB print. Technicolor prints were very low grain and very saturated, with some slight softness due to the three color passes being not perfectly registered. You would sometimes see red halos around bright highlights.
ENR prints were like a black and white sliver layer being laid on top of the color image - contrasty and desaturated, deep rich blacks, grainy silvery highlights and thick midtones. They also tended to appear sharper because of the extra contrast.
Opal
Opal
