Ppaint/dye for blacking Chinaballs
#1 Daniel Meier
Daniel Meier
  • 99 posts
  • Leipzig, Germany
Posted 30 May 2017 - 06:20 PM
I was just wondering how to darken those chinese paper lanterns to control the light output.
Which is the best suited paint for that matter?
Also was looking for a way to paint my white polystyrene panels black on one side to use them as neg. fill.
Any suggestions?
  • 20083 posts
Posted 30 May 2017 - 06:40 PM
I usually use that lightweight black plastic tablecloth material that's like a thin ripstock for clipping to one side of a paper lantern, or newspaper spray-painted black would work.
For blacking one side of beadboard, I'd either tape black showcard or black duvetine to the back side.
#3 Adrian Sierkowski
  • 7394 posts
Posted 30 May 2017 - 06:42 PM
Typically Ill reach for some black-wrap, on a bigger show we'll buy rolls of it and save what we cut to re-use on china balls as skirting.
#4 JD Hartman
JD Hartman
  • 1768 posts
  • Edison, N.J. U.S.A.
Posted 09 June 2017 - 05:02 AM
The paper is too thin to die or tint and become opaque.  As already suggested, cover with Duvetyn, Commando cloth, black wrap or black plastic.
If your trying to produce a directional soft light, a Mole 1k zip might be a better choice.
#5 David Mullen ASC
  • 20083 posts
Posted 09 June 2017 - 11:34 AM
Unless you are using a rigid lantern lock system, putting duvetine on one side of a paper lantern tends to cause it to swing to one side.
#6 Adrian Sierkowski
  • 7394 posts
Posted 09 June 2017 - 11:39 AM
this is why i recommend black-wrap, far less weight. (or if you're in a pinch just regular aluminum foil)
