Where can I buy the tape used to keep the film on the reels?
#1 Daniel D. Teoli Jr.
Daniel D. Teoli Jr.
  • 303 posts
  • Born in L.A....NYC is 2nd home...Rustbelt is home base.
Posted 24 June 2017 - 10:15 AM
I have a ton of old regular 8 films I'm working on. The reels have a skinny piece of tape used to keep the film tight on the reels as to not unwind. Does anyone still sell this tape? What is it called?
#2 Tyler Purcell
Tyler Purcell
  • 4469 posts
Posted 24 June 2017 - 10:28 PM
I assume you're referring to the tape on the outside of a full reel.
If that's the case, I use paper tape and a standard dispenser. That's kind of the industry standard.
A long time ago, they used a plastic tape, you can use pretty much any "magic tape" solution like scotch tape. Just cut it into little strips and it works fine. Sometimes the really good dispensers cutting tool is good enough.
#3 Mark Dunn
Mark Dunn
  • 2901 posts
Posted 25 June 2017 - 02:56 AM
If you're using a tape splicer, a bit of splicing tape will do. Just fold a tab into it so it can be pulled off easily. It's good for about 35 years, but I recently had some 16mm in from 1975-6 and many of the tape splices parted. But that's the quid pro quo for its not turning sticky with age. Ordinary adhesive tapes tend to do that.
My own splices from 1978 onwards are fine. I assume it depends on the brand of tape.
Edited by Mark Dunn, 25 June 2017 - 02:59 AM.
#4 Perry Paolantonio
Perry Paolantonio
  • 589 posts
  • Boston, MA
Posted 25 June 2017 - 06:29 AM
We use acid-free artists tape. Paper backing, low tack adhesive (that doesn't leave residue on the film), and it's something you can order on Amazon in a variety of widths. We use 1/4" for 8mm and 3/8 or 1/2" for 16mm/35mm.
A roll lasts a really long time, so don't be put off by the cost of the tape ($10/roll or so).
#5 Martin Baumgarten
Martin Baumgarten
  • 212 posts
  • Plattsburgh, New York U.S.A.
Posted 03 July 2017 - 05:47 PM
Those 3 inch diameter fat rubber bands that various office supply places sell work great for the 50ft reels.  I put a twist on one while placing it on the film and it makes it easier to grab the rubberband to remove it.  I do suggest the film be snug on the reel and not loosely wadded up of course.  The tape suggestions are good too.  You can get a bag of rubberbands for pretty cheap though and they are reusable as well.
