DIY bounce/diffusion
#1 Eric Soto
Eric Soto
  • 68 posts
  • Toronto
Posted 26 June 2017 - 11:46 AM
Hey everyone, I am looking to build a 6x6 frame with some unbleached muslin on it. The price of muslin used for professional film purposes is out of my budget so a few questions come to mind that I would appreciate any help on. I will be using tungsten lights, the most powerful being a 1k.
1. Is cheaper, more affordable muslin that can be bought at a local textile place be trusted not to catch fire?
2. If I want something for diffusion and a bounce should I use cheap muslin for both? or maybe go with some type of silk ? so long as it does't catch fire. Or use both ?
3. In terms of being able to be set up quick, and easy to transport (relative to being a DIY and not professional gear) what is the best suggestions for a frame? Wood? Staple the muslin/silk onto the wood? Tie it through grommets? Or use PVC pipes?
I understand that these might be easy questions that have quick solutions that i could google but I would like to know your experiences doing this and the most effective and affordable way to achieve it, again, in your experience.
Thanks, appreciate it!
Eric
#2 Phil Rhodes
  • 12301 posts
Posted 26 June 2017 - 12:50 PM
PVC is too flexible. I made mine out of commercial one-inch aluminium tube stock (google will find somewhere conveniently near to you) and these fittings. Those are in the UK but I suspect there'll be somewhere local for you to get something similar. You could use the steel advertised alongside those clamps, and it might be more rigid, but it will also be heavier and go rusty.
I replaced the allen screws with commercially available handwheels similar to these. They're a standard M8 size and now they're tool-free.
Mine is 8x8 based on the standard lengths of aluminium stock, and each side breaks down into two four-foot lengths using straight couplers. As such, the same parts can also be used to construct a four-by-four frame as well, though I haven't made any panels that size.
I used white ripstop nylon - it's essentially equivalent to what the film industry calls gridcloth. The only downside is that it may not behave in an exactly equivalent manner to other diffusion materials, but it does the job.
The panels are held in using bungee toggles like these. They're not perfectly ideal, being a bit long by default - you need to put a lot of tension on the fabric to keep it flat, especially with things like blue and green screens. Right now you have to wrap the bungee once around the tube to put more tension on it. I should really go through and shorten all the bungees by retying the knots and removing the excess.
The largest amount of actual construction was for the hardware to clamp the frame to the two stands. I bolted a piece of angle to the top of a junior pin to create an upright surface, then bolted a piece of three-quarter inch box section to that using a clamping lever (sometimes called a Kipp handle), with the nut captive inside the box. A claw clamp either end of the box allows the frame to be clamped and held at any angle (and they're good for clamping other tubular objects, too.)
About the only thing you're likely to want to send out is the sewing. I had polypropylene webbing sewn into the edges, to create a tough base on which to mount the D-rings through which the bungees thread. This arrangement is probably better than most of the commercial ones, which seem easily torn by applying too much tension on a windy day.
I got a cheap tripod bag from eBay to put it all in. I remember having to look for quite a big one to accommodate four-foot lengths of metal.
Assume all muslin (and all fabrics per se) will be flammable; spray them with fire retardant.
I can take photos if it helps.
Best
  • 2
#3 Theodore P Rysz III
Theodore P Rysz III
  • 4 posts
Posted 27 June 2017 - 10:58 AM
Hey Eric,
See my response to your questions within the quote.
- This should be fine, it just depends on how close you have the unit to the material. That would be the same of "film grade" muslin as well.
- If you could afford both, I would be both. That way you can see the difference in quality of both.
- I think that Phil best answered this.
#4 Edward Lawrence Conley III
  • 192 posts
  • Los Angeles CA
Posted 27 June 2017 - 12:07 PM
Look around Toronto for a canopy supply shop or Garden center.
http://mpcanopies.co...&category_id=13
#5 Eric Soto
Eric Soto
  • 68 posts
  • Toronto
Posted 25 August 2017 - 06:41 PM
Best
Hey sorry for the late reply, but thank you so much for the info. It will help out a lot. I will be trying it out soon.
