Light Meters Sekonic L-478D-U vs L-858D-U
light meter sekonic L-478D-U L-858D-U
#1 Alexander Sutton Hough
  • 34 posts
Posted 27 June 2017 - 06:39 PM
Hi, I have been using for the past few years been using my Sekonic 508. (not the cine version) and want to upgrade.
I am looking at the Sekonic L-478D-U with a 5 Degree Spot Viewfinder adapter and the new Sekonic L-858D-U.
Besides having the built in 1-4 degree spot viewfinder what would also be a crucial reasoning to spend the extra $200-300 more for the Sekonic L-858D-U?
Would not having the ability to do 1-4 degree spot and be stuck at 5 degrees be a deal breaker? How often do you need the 1-4 degree spot?
#2 Michael Rodin
Michael Rodin
  • 266 posts
  • Moscow
Posted 28 June 2017 - 03:44 AM
I constantly use 1 degree spot to get isolated readings of specific textures or details. Also helps to separately meter lit and shadowed sides of faces.
With a 5 degree lens you're often doing what's called "integrated metering" i.e. taking average from highlights, half-shadows, etc, which kind of defeats the purpose of spot metering - the precise control of contrast. You can get closer to the subject to meter a smaller area but that slows you down and once again defeats the purpose - spot readings are usually best done from camera position as they're all about reflected light.
Edited by Michael Rodin, 28 June 2017 - 03:45 AM.
Also tagged with one or more of these keywords: light meter, sekonic, L-478D-U, L-858D-U
