Alexa Mini 3.2k Zoom Lenses
#1 Theo Angell
Theo Angell
  • Los Angeles, Seattle
Posted 12 July 2017 - 08:19 PM
Trying to figure out which 10:1 and 12:1 zoom lenses cover the Alexa Mini at 3.2k. Any personal experiences? I know the old Cookes and Angenieuxs as well as the Angenieux Optimo 24-290 won't cover.
#2 Dom Jaeger
Dom Jaeger
  • 1928 posts
  • Melbourne, Australia
Posted 13 July 2017 - 03:02 AM
I don't have the combination on hand to test, but you might find the 24-290 is OK. According to the Arri sensor coverage data sheet for Alexa Mini the image circle diameter required for 3.2K 1.78 is 30.3mm, which is only fractionally larger than Angenieux's conservative 30mm image circle diameter figure for the 24-290. To put it in perspective, a very slight aspect ratio change to 1.85 reduces the image circle requirement to 30mm. The image circle of zooms is often smallest at the wide end and quickly expands, so it may be fine from say 25-290.
The older Angenieux and Cooke 10x zooms tend to be around a 28mm image circle diameter at the wide end, so definitely won't cover through their whole ranges.
I can't think of any other modern 10 or 12x zooms that wouldn't cover a 30.3mm image circle, but you could check manufacturer specs or available image circle databases.
#3 Theo Angell
Theo Angell
Posted 13 July 2017 - 10:55 AM
Thanks Dom, we will test the 24-290, there are indeed conflicting reports, but most agree that there is vignetting (one person actually said all the way up to 70mm). We'll we how bad it is.
