XTR vs XTR Prod
#1 Joshua Echevarria
Joshua Echevarria
  • 5 posts
  • New york
Posted 31 July 2017 - 04:29 PM
Hey been looking into an Aaton s16 camera but I'm a bit confused about the differences between the various models. I can't seem to find any clear cut answers anywhere. Thanks!
#2 Gregg MacPherson
Gregg MacPherson
  • 1953 posts
  • New Zealand
Posted 31 July 2017 - 04:41 PM
This info,  originally posted by Nathan Milford, has been re posted a couple of times by others.  May be useful.......
Nathan Milford posted this a few years ago when he was working for AbelCineTech:
1974 to 1982 - Aaton LTR (#250 to #950)
- Most bodes were 16mm only
- 32fps Top Speed
- Mechanical Drive for Mags
- Optional Light Meter
- Optional Relay optics for VR 30 tube tap.
1982 to 1985 - Aaton 54LTR (#950 to #1300)
- 54fps Top Speed
- Super 16
1986 to 1992 - Aaton XTR (#1300 to #1785)
- 54fps Top Speed
- Magnetic Drive
- Super 16
- Light Meter
- Relay Optics for VR30 Tub Tap
1992 to 1994 - Aaton X0plus (#1785 to #1900)
- 60fps Top Speed
- Magentic Drive
- Super 16
- Screw-in 15mm front rods
- Designed to be upgraded to the XTRplus
- Optional port for integrated CCD video tap
1992 to 1994 - Aaton XTRplus (#1785 to #1900)
- 60fps Top Speed
- Magentic Drive
- Super 16
- Light Meter
- Integrated CCD video tap
- Aaton Code
- LCD Side Display
1994 to present - Aaton X0plus (#1900 and above)
- 75fps Top Speed (Tri-Phase Motor)
- Magenetic Drive
- Super 16
- Lower power consumption
- Upgradable to XTRplus
1994 to present - Aaton XTRplus (#1900 and above)
- Magenetic Drive
- Super 16
- Light Meter
- AatonCode
- Side Display
1994 to present - Aaton XTRprod (#1900 and above)
- Magenetic Drive
- Super 16
- Light Meter
- AatonCode
- Illuminated Side Display
- Built in speed control in .001fps increments
- Variable shutter
These are sort of rough as there are grey areas where upgrades have been performed where you have amalgamations such as the XC, LTR-X, XTR-j and what not.
Edited by Gregg MacPherson, 31 July 2017 - 04:43 PM.
#3 Joshua Echevarria
Joshua Echevarria
  • 5 posts
  • New york
Posted 31 July 2017 - 04:45 PM
Thanks Greg! Never saw that list before. Appreciate it.
#4 Stephen Perera
Stephen Perera
  • 302 posts
  • Gibraltar, Europe
Posted 14 September 2017 - 07:01 AM
add to that list the Aaton XTR XC which is an XTR without any electronics which is what I have.....serial number 1599...according to Allan Giles in the UK (service guru) it was produced as like a back up for when you're out there in the middle of the jungle filming and your electronics on the other Aaton give up.....mine is a regular 16 as previous owners swapped out the S16 capabilities.....well documented on this forum hahah
