Suggestions for a night exterior
23 replies to this topic
#1 Phil Rhodes
  • 12301 posts
Posted 15 August 2017 - 01:33 PM
Hello folks.
I may well have to light this at night for next to no money.
The action is that a young woman is trying to help someone she believes is trapped inside. She approaches the house. No lights are on inside, but we can assume some external accent lighting might be running. She can't get in; checks around, peering through the windows, then forces the front door and goes inside.
It's a near-future sci fi, near enough that houses like that would reasonably exist, and I would like to do something to make it look that way. Perhaps we can do something props-wise about a cool blue glowing panel by the door which acts as a doorbell, message system, or something. We could cheat in some illuminated bollards, or even assume some just-out-of-shot street lighting.
I would rather avoid an orange sodium streetlit look; there's one just out of shot to the right, but not much else. Moonlight would be nice, so, obviously, an 18K on a cherrypicker, except... no. We should have access to several 240V/13A power outlets, each capable of about 3KW. Largest instrument is therefore a 2.5K HMI.
This instinctively sounds grossly insufficient, although Arri's data suggests that an M18 will develop more than 250lx at 20m with a beam diameter of over 23m. At ISO 400 and 25fps with a 180-degree shutter, that's almost a 2.8, though one would rather be at f/4 for sanity and reliable optical performance. It will cover a 16m area at nearly 500lx, which should be 2.8 and a half or thereabouts.
I have a few ideas but I'd be very grateful for any thoughts.
Phil
#2 Miguel Angel
Miguel Angel
  • 861 posts
  • Spain / Ireland / South Africa
Posted 15 August 2017 - 02:06 PM
You can do several things on this but you need to do two things:
1) Block the scene.
2) Take a photo at night.
If I weren't able to put a cherry picker with a 16x16 ultrabounce on it and bounce a 2.5K off it I would go from the ground and keep the light lateral.
You could use a 2.5K with Peacock blue (for example, or keep it white) through a 4x4 frame (or 2) and then through a 12x12 frame from as far as you can get for the ambience.
Then, if you have the money you could use a couple of Selects through 4x4 frames for the close-ups.
Also, those little roads.. you could put a 2K with Bastard Amber / Sodium Vapor on each road far back just to create some colour contrast.
Have a lovely day! ;)
#3 Macks Fiiod
Macks Fiiod
  • 1532 posts
  • Og from DC, Now in NJ
Posted 15 August 2017 - 02:08 PM
What comes to me is night darkness with a cyan illumination and small white-yellow practical sources scattered throughout, maybe dropped back into the bokeh of the lens.
#4 Miguel Angel
Miguel Angel
  • 861 posts
Posted 15 August 2017 - 02:20 PM
Actually, you could use something very effective to create "points of light" in the background which is putting single photoflood bulbs on c-stands scattered in the background with different colours :)
#5 Marcel Zyskind
Marcel Zyskind
  • 144 posts
  • Cph
Posted 15 August 2017 - 04:37 PM
I suggest having a couple of skypanels on boom arms. They output plenty light on next to nothing power. You can easily soften them. Dial in exactly the color you'd like. I love them.
#6 Phil Rhodes
  • 12301 posts
Posted 15 August 2017 - 06:36 PM
skypanels
That crackling sound would be hell freezing over, I believe.
But seriously - thanks, and I'll look into it. I may be able to rustle up a couple of 8x8s, which would be half the area of the 16x16!
But really, a 2.5K into a 16x16, over that sort of area?
#7 Stuart Brereton
Stuart Brereton
  • 3396 posts
Posted 15 August 2017 - 07:21 PM
This was lit with a single M18 through a 12x12 Light grid. Red Dragon @800 ISO. I can't remember the stop, but we were shooting with Super Baltars, so it was probably f2.8. The frame and lamp were only a few feet out of shot, so there was a 12x12 double net T-boned to slow down the light on the right side of the house. I'll probably take it down further in color-timing.
#8 Miguel Angel
Miguel Angel
  • 861 posts
Posted 15 August 2017 - 07:23 PM
There you go!
#9 Justin Hayward
Justin Hayward
  • 955 posts
  • Chicago, IL.
Posted 15 August 2017 - 09:22 PM
If you're not replicating street lamps or moonlight, you don't have to light the house from top to bottom if you don't think that's possible.  It's a large house, but if you have to, you can light some of the roof, a little of the middle and a little of the bottom and I'll (as the viewer) know the size and scope of the house from that alone.  As long as it's all dim enough, I won't care where the light is coming from, because I won't notice it's lit... which would be the objective.  It would help to light the houses on the right and left in a similar way, but none of this requires big lamps as long as you have fast lenses, because I assume you want it to be dark overall.
#10 Justin Hayward
Justin Hayward
  • 955 posts
  • Chicago, IL.
Posted 16 August 2017 - 09:52 AM
On a side note, since replacing skies is so easy now, have any of you tried shooting traditional day for night, then replacing the sky with stars and the moon?  I'm curious if that would work or look too weird.
#11 Phil Rhodes
  • 12301 posts
Posted 16 August 2017 - 10:34 AM
Not sure I'd go for that. Too much chance of the 1970s disaster movie look.
#12 Justin Hayward
Justin Hayward
  • 955 posts
  • Chicago, IL.
Posted 16 August 2017 - 11:06 AM
Probably.  I'm just curious if anyone here has tried it in like a desert scene or something.
#13 Miguel Angel
Miguel Angel
  • 861 posts
Posted 16 August 2017 - 06:41 PM
We did that on "Broken Hugs" from Almodovar in one shot in Lanzarote which I don't remember if it is in the movie or not, I saw it on the grading suite and it looked great!
It was a shot of a car driving through the mountains in Lanzarote.
Have a good day.
#14 Josh S Wilkinson
Josh S Wilkinson
  • 6 posts
  • Dallas
Posted 16 August 2017 - 09:49 PM
Not sure if budget or power is more the concern. But you could look into aadyntechs punch plus, better output than a 2.5k and only runs at 5 amps. Could potentially double them up into a 12x12 or space them out.
They have become my favorite for budget exterior stuff.
#15 Michael Rodin
Michael Rodin
  • 265 posts
  • Moscow
Posted 17 August 2017 - 03:53 AM
Look at the photometrics - it's weaker than a 1200 SE PAR, let alone a 2,5K.
"Brighter than a 2,500 watt HMI", they say. Maybe, brighter than a 2,5 softlight made in '70s.
Phil, you should take a look at genny rental prices if you haven't. At least here, it's cheaper to rent a 1,5-ton truck (which you'll need anyway) with an onboard 36kW genny and a couple 6Ks than a package of high-output LEDs like S120 Skypanels.
I'll second Miguel's sugesstion to fire a couple PARs into an Ultrabounce high above. You can try lighting houses in background with a direct flooded fresnel broken up with a branchaloris, will help create more contrast on BG. Be sure to have some kind of glowing highlights in BG (lit window, streetlight, anything) or some higly specular things giving highlight - with nothing overexposed in frame, it won't look as dark.
#16 Josh S Wilkinson
Josh S Wilkinson
  • 6 posts
  • Dallas
Posted 17 August 2017 - 04:17 AM
I have and I use them frequently. Based on Arri's App, its pretty spot on to a 2.5k bulb in an M40, within a 1/5 of a stop. Compared to any cheaper fixture, its usually brighter.
#17 Michael Rodin
Michael Rodin
  • 265 posts
  • Moscow
Posted 17 August 2017 - 04:28 AM
Tried the app...
Arri 2,5 fresnel at full flood - 6000 lux @ 4,5 meters
"Punch Plust" with a 55 deg diffuser - 1830 lux @ 4,5 meters
And that's a fresnel which's the least efficient of them all. In a narrow-beam application (like firing into a mirror) this LED is more than 20x weaker than a PAR with a safety glass (no lens) and 2-5x dimmer than a lensed par.
#18 Josh S Wilkinson
Josh S Wilkinson
  • 6 posts
  • Dallas
Posted 17 August 2017 - 05:00 AM
Tried the app...
You're comparing apples to oranges.
For 1, an M40 puts out 2800 FC at a 38 degree beam at 10ft. Thats the widest the app shows.
The Punch Plus's normal beam is 19 degrees with no "lens". The lens are just plastic diffusion panels, they're terrible, they easily eat 1-2 stops of light.  If you're pushing this through a silk or bouncing it there is no reason to use them.
An M40 puts out 7000 FC at 18 degree at 10 ft, Punch plus puts out 6000 FC
And thats basically the best par fixture in production.
You can not like LEDs, thats cool. Don't go putting out false info though.
Edited by Josh S Wilkinson, 17 August 2017 - 05:00 AM.
#19 Phil Rhodes
  • 12301 posts
Posted 17 August 2017 - 05:18 AM
I was going to say (hopefully a bit more sympathetically) the same thing. It's incredibly easy to be hoodwinked by LED output claims. They are often absolutely outrageous.
That LED is a bit less than 600 watts' worth. LED and HMI have broadly similar luminous efficacy (very recent, high quality LEDs may be fractionally better, but not enough to make a worthwhile difference in this comparison.) It is not plausible that a 600-watt LED has the same output as a 2.5KW HMI.
  • 1
#20 JD Hartman
JD Hartman
  • 1791 posts
  • Edison, N.J. U.S.A.
Posted 17 August 2017 - 05:55 AM
Did anyone read the first line in Phil's post?    "....no money."  Well, at least Miguel did.
Just throwing it out there, while more power hungry, HMIs will be cheaper to rent than Skypanels.
