Trouble Finding the Correct Crop Factor Formula
lens directors viewfinder alan gordon mark v
#1 Kendrick Satterfield
  • Grand Rapids
Posted 21 August 2017 - 01:11 AM
Apologies if this question has already been addressed, but by what I could tell actual mathematical calculations haven't been brought up.
Right now I have an Alan Gordon Mark V director's viewfinder. I'm trying to figure out what the exact focal lengths (Give or take 2-3 millimeter) would be for commonly used sensor sizes such as full frame, Canon aps-c, and the Red Scarlet.
After calling Alan Gordon this is what I know for sure. The 35mm window is based off of super 35 3-perf film, 24.9 x 13.9. My baseline that would remain consistent on the viewfinder for these calculations would be the the 35mm window with a 16:9 aspect ratio.
My question is as I find out the crop factor each sensor has in relation to the viewfinder do I need to apply that 16:9 aspect ratio to the sensor sizes? This part confuses me. In my mind I would want to leave the sensor sizes untouched.
I suppose I'm just thoroughly confused. If someone can shed some light on what would be an appropriate course of action to take in figuring out what formula to use I would be so grateful.
#2 Brian Drysdale
  • 5195 posts
Posted 21 August 2017 - 07:21 AM
You can work out a factor using this:
https://www.abelcine.com/fov/
#3 David Mullen ASC
  • 20072 posts
Posted 22 August 2017 - 09:22 AM
If the aspect ratio doesn't change then you can just either the horizontal or vertical measurement to figure out the crop factor. For example, the crop factor between a format that is 36mm wide versus 24mm wide is 36 divided by 24.
#4 Kendrick Satterfield
  • Grand Rapids
Posted 24 August 2017 - 12:35 AM
Super helpful, thanks Brian!
#5 Kendrick Satterfield
  • Grand Rapids
Posted 24 August 2017 - 12:43 AM
David, that's a good point. Thanks for reminding me of that.
Also tagged with one or more of these keywords: lens, directors viewfinder, alan gordon, mark v
