Old filmstock test
12 replies to this topic
#1 Adam Frisch FSF
Adam Frisch FSF
  • 2027 posts
  • Los Angeles, USA
Posted 29 August 2017 - 01:35 AM
First test is on 35mm stock. I'll upload the 16mm footage next week or so.
This was all very impromptu, I just grabbed a girl that happened to work at the rental house, I had no real lights and nobody to pull focus. So yo have to see past all that. But still interesting.
I purposefully chose the oldest film cans I had laying around, and/or went for the ones with the highest ISO or most corroded can. As you can see in the case of the first example 5283 800ASA stock from 2001, it's almost unusable. This was one of the "flop" stocks from Kodak that nobody liked, and it was only produced between 2001 and 2003. It was considered too grainy even then.
These films were stored for about 3 years frozen, then in various room temperature settings, attics, cellars etc. It was also shipped to the US from the UK, so as you can see, there is some X-ray damage mainly on the 800ASA. Lower ISO films are less susceptible to X-ray damage.
In general, you will see that film loses its sensitivity as it gets older, regardless of it's speed. And by exposing at rated ISO, you'll see that the gamma rays and the decay have raised the base levels up so this is now underexposed. Once you start to get to 2 stops of overexposure, you'll see the film starts to behave a lot better and grain is suppressed.
I bracketed most of the the stocks between -1 and +2 of exposure. In the case of the 800ASA stock I forgot to change ISO setting on my light meter from 200ASA, so that stock is actually overexposed twice as much - meaning, if it says +2 stops it's actually +4. Which still didn't help it much.. :)
In telecine it was not te objective to show the exposure differences, hence the film was normalized to look about the same exposure-wise, so as to easier be able to judge grain levels between the clips. Interestingly, on the vectorscope, the red layer and the green layer (but especially the red) showed the most X-ray/storage damage, whereas the blue layer was almost unaffected. Meaning, if you had to use really old stock that was damaged, you'd be better off lighting it very blue. It would show up less.
Kodak 5283 800ASA from 2001 with X-ray damage:
But here's the most interesting test of them all. This is the oldest can I could find in my collection and it's from 1996. So almost 22 year old film. It was stored the same way as the 800ASA, shipped and X-rayed the same way. But as you can see, it performs much much better. In fact, at +2 stops of overexposure (towards end of clip), it could quite easily be used today. Colors get a little dull and the contrast increases, but all these things could be mitigated if one was so inclined and hell-bent on using it (Varicon, LowCon, pre-flashing, post-flashing etc). Very interesting.
Kodak 5293 200ASA from 1996:
Conclusion for old still film has always been to add a stop of exposure for each decade when shooting expired film. I would say that's conservative when it comes to MP film (where it's storage has been less than optimal). It seems to me that for anything below 200ASA, I would add 1.5stops for each decade. For ISO's above 200, I'd say that should be 2 stops per decade. And for 800ASA, well, as you can see, +4 stops is not nearly enough. I wonder how the grain structure would have behaved at 6-8-stops of overexposure?
I hope you found this little non-scientific test informative. Next week I'll upload the two 16mm filmstock tests I did.
#2 Nicholas Kovats
Nicholas Kovats
  • 518 posts
Posted 29 August 2017 - 07:20 AM
Great tests and thank you for undertaking this. I now realize that I did not compensate sufficiently for some out of date V2 200T 35mm tests recently. Should be interesting when it comes back ftom the lab and its scanned.
Edited by Nicholas Kovats, 29 August 2017 - 07:20 AM.
#3 Tyler Purcell
Tyler Purcell
  • 4096 posts
Posted 29 August 2017 - 12:50 PM
Nice test and thanks for uploading it. I've shot a lot with outdated stock, but haven't yet seen stuff with muted colors like that. I would love to see what those tests looked like "corrected" and if its even worth it. I actually have a refrigerator FULL of stuff from the 90's, both 35mm and 16mm of various kinds incuding some 800. I'm gonna snip test some of it, just to make sure it's not completely bad, as ya never know. But if some of it's even remotely good, we're gonna make a bunch of short projects with it.
#4 Adam Frisch FSF
Adam Frisch FSF
  • 2027 posts
  • Los Angeles, USA
Posted 29 August 2017 - 10:05 PM
Tyler, it will fail the snip test most likely. But that does not mean it's not usable. That's why snip tests have limited value I find. The tolerances are pretty tight and it only takes a few years before the stock will fail the snip, but still be perfectly OK to shoot with a little overexposure if you can accept a little more contrast, grain and color shift.
#5 Stuart Brereton
Stuart Brereton
  • 3347 posts
Posted 29 August 2017 - 11:07 PM
Is that Kelly Samuels?
#6 Tyler Purcell
Tyler Purcell
  • 4096 posts
Posted 30 August 2017 - 01:19 AM
Ohh yea, totally fail... but the numbers are nice to look at just to gauge how far off they are.
I just wanna know if the color shift is too bad... just so I don't do anything "critical" with it.
#7 Adam Frisch FSF
Adam Frisch FSF
  • 2027 posts
  • Los Angeles, USA
Posted 30 August 2017 - 08:03 AM
Stuart - I think it is. Def Kelly, not sure about her last name. She's customer relations at Camtec. Very helpful young woman who volunteered for my little impromptu test.
#8 Stuart Brereton
Stuart Brereton
  • 3347 posts
Posted 30 August 2017 - 08:48 AM
She used to work as an AC, or maybe still does. She came in and day played on a movie I did a couple of years back. Really helpful and fun.
#9 Edgar Nyari
Edgar Nyari
  • 90 posts
Posted 30 August 2017 - 09:54 AM
This is great! Thanks. As a user of short-ends, I wish there were more tests like this.
Is there any reliable information as to when does x-ray damage happen? I mean film is shipped on a regular basis everywhere. If you buy fresh stock from various companies, they often ship it to you by mail. So what happened to that roll of 800ASA?
#10 Stuart Brereton
Stuart Brereton
  • 3347 posts
Posted 30 August 2017 - 10:10 AM
X ray damage is cumulative, so one or two trips through the machine is unlikely to cause problems. It's when it's repeatedly scanned that you'll start to see issues, such as taking film on a multi destination trip where it is scanned at every airport.
It affects fast film more than slow film, but there's little info as to how quickly it happens, because x ray machines vary in power.
#11 David Mullen ASC
Posted 30 August 2017 - 11:33 AM
There is also just regular cosmic radiation randomly hitting the film (and us) over time... As Stuart says, the slower the film, the less sensitive it is both to light and to radiation.
#12 Karim D. Ghantous
Karim D. Ghantous
  • 65 posts
  • Melbourne, Australia
Posted 03 September 2017 - 09:27 PM
Thanks for doing this. I look forward to seeing the 16mm stuff. BTW I don't suppose you could post a few scans of individual frames?
#13 Robino Jones
Robino Jones
  • 27 posts
Posted 07 March 2018 - 06:29 PM
Thanks for sharing this great test - I purchased a bunch of expired stock, some of which is 5293.
How do you figure out the year of manufacture? I got the PDF from Kodak about stock identification but you need to check edge code on the actual film.
There are numbers on most of my film cans and on the tape around the can but not sure if it can be identified with those, most are factory sealed.
I could probably open some cans and cut little pieces and hand develop them in a still tank with some D76 to remove emulsion / clean the remjet to read the edge code.
Is it worth it or should I just shoot it and overexpose 1-2stop and see what happens?
