What is this?
#1 John Carty
John Carty
  • 24 posts
  • AZ
Posted 30 August 2017 - 01:16 PM
I was looking at a 16mm bolex camera and I noticed this  little strap like thing inside of the camera, I have seen other bolex's and never noticed this piece in their pics.Any idea what this is? and does the camera really need it.
#2 Jean-Louis Seguin
Jean-Louis Seguin
  • 762 posts
  • Montreal, Canada
Posted 30 August 2017 - 07:01 PM
This is only found on the Bolex H8 8mm cameras. 8mm film could be purchased in 25, 50, and 100 foot lengths and the guides could be adjusted at three different positions to keep the film from unraveling.
  • 1
#3 John Carty
John Carty
  • 24 posts
  • AZ
Posted 31 August 2017 - 01:20 AM
Thanks for the info, so this camera is a 8mm bolex not 16mm, it is hard to tell from the picture but the loop formers look kind of wide that made me think it could be a 16mm.
#4 Brian Drysdale
  • 5287 posts
Posted 31 August 2017 - 02:01 AM
It will be regular or standard 8mm, which is 16mm wide before it's split into 8mm.
#5 John Carty
John Carty
  • 24 posts
  • AZ
Posted 31 August 2017 - 10:25 AM
So  could that  camera still use 16mm film stock?  or would the result be that only half your film would be exposed
#6 aapo lettinen
aapo lettinen
  • 1168 posts
  • Finland
Posted 31 August 2017 - 10:45 AM
with standard8mm camera ("2x8mm" camera) you have 16mm wide film stock which has perforations on both sides and double the amount of perforations per feet compared to 16mm camera film.  with the 2x8mm camera, you will first shoot one side of the film (8mm width of the total 16mm width), and when done, you remount the takeup spool to the feed side but flip it upside down so that you will now expose the other side of the film, again 8mm wide exposure.
After developing, the lab separates the sides by slitting the film from the center to two reels.
So you will run the raw stock TWO times through the camera to first expose one side of the film and then the other side, and AFTER DEVELOPING the exposed film is slit in two separate 8mm reels. If you look the camera's aperture plate you'll see that there is a regular8mm size aperture which exposes only one side of the 16mm raw stock at a time.
The film stock has double the amount of perforations compared to regular 2side perforated 16mm film so you can't use normal 16mm film with it, you'll need raw stock which is specifically perforated for a 2x8mm camera (that be, it has double the amount of perforation holes compared to similar 16mm camera stock and the holes are on both sides of the film)
Edited by aapo lettinen, 31 August 2017 - 10:49 AM.
  • 2
#7 John Carty
John Carty
  • 24 posts
  • AZ
Posted 31 August 2017 - 09:43 PM
Thanks for all the great answers,it was a camera that I had seen on e-bay and the guy had it listed as a 16mm, I kind of thought to myself that it was not so I decided to ask the experts. Many thanks again to all that  answered.
John
