Baltar 75mm lens mount?
vintage lens old lens baltar
10 replies to this topic
#1 Chris Lange
Chris Lange
  • 61 posts
  • Minneapolis, MN
Posted 07 September 2017 - 03:10 PM
I was wondering about the mount of this lens.  I'm trying to adapt to micro 4/3.  It looks like Arri standard, but it didn't mount to my Arri standard adapter.  Does anyone know which mount this is?
Thank you
#2 Dom Jaeger
Dom Jaeger
  • 1696 posts
  • Melbourne, Australia
Posted 07 September 2017 - 09:03 PM
It does look like Arri Standard.. can you tell why it doesn't fit your adapter? What's not working? Arri mount rear diameter is 41mm.
It looks like the early type that needs to rotate inside the camera mount.
It's a little odd because Baltars weren't made for reflex cameras, but that mount has a bevel which would seem to be for clearing a 45 degree mirror and matches where the mirror is relative to the locating key on a Standard mount Arri.
I don't think I've ever seen Baltars in Arri mount, more likely to be in Mitchell or Eyemo mount, but that doesn't look like either of those. Eyemo mount is similar, but doesn't have that groove near the rear.
#3 Chris Lange
Chris Lange
  • 61 posts
  • Minneapolis, MN
Posted 08 September 2017 - 08:22 AM
Thanks for the response.
Its the small slot / groove of the mount - its width is too small for the adapter's metal tab to fit.  I think I will try to file the adapter's metal tab's sides down so that it can at least insert.
I've also unscrewed the back focus ring (see photo) to see the design of the (helicoid?).  So it seems like the focus moves the whole lens forward and backward.
#4 Alex Nelson
Alex Nelson
  • 36 posts
Posted 08 September 2017 - 10:25 AM
Baltars were sold in virtually every mount used between their release in the late 1930's and the release of the Super Baltars. For the most part, that means Eyemo, Debrie, Mitchell (almost all variations), Cameflex, Wall, etc. I have seen a single 40mm Baltar in Arri standard mount, but I don't think any of the three wider focal lengths (25, 30, 35) would reliably clear a reflex mirror. The 75mm, though, is guaranteed to work with pretty much any reflex system or mount because of its relatively long rear working distance. It also covers full-frame 35mm without issue (as do all Baltars longer than 35mm)  and can give you a really pretty image if the glass is in reasonably good condition.
#5 Chris Lange
Chris Lange
  • 61 posts
  • Minneapolis, MN
Posted 09 September 2017 - 07:11 AM
Alex, thanks for the info.
As it turns out, after filing the metal tab of the adapter down, it still did not work.  I did manage to fit the adapter's tab into the arri mount's groove, though after that, it is tight and the focus dial is just kind stuck.  It's not a solution.
Edited by Chris Lange, 09 September 2017 - 07:12 AM.
#6 Freya Black
Freya Black
  • 4162 posts
Posted 10 September 2017 - 10:54 AM
It looks like it could possibly be OCT-18 to me.
A bit of a weird idea for a Baltar lens though but the tab thing is a characteristic of OCT-18 as are the mickey mouse ears. I can't tell if that is the case though as one of the big differences is the diameter of the mount but Arri Standard and OCT-18/OST-18 look very similar.
The focus dial doesn't move as the entire lens is supposed to roatate in the mount.
That's what the tab thing is about too.
IIf I had to guess I would say that it was Eyemo Eyemax mount  especially given that it is a Baltar lens.
I can't tell the size/scale from the photos though.
Freya
#7 Alex Nelson
Alex Nelson
  • 36 posts
Posted 11 September 2017 - 10:59 AM
The easiest way to use it with your camera is to pull the optical cell off its focus threads (which is much easier than it sounds) and attach it to an inexpensive focus helicoid. Another fellow did exactly that with a 75mm Baltar to use it with an EF mount. (http://www.cinematog...67913&hl=baltar)
  • 1
#8 Chris Lange
Chris Lange
  • 61 posts
  • Minneapolis, MN
Posted 12 September 2017 - 02:40 PM
Alex - Thanks for the old post.  That makes sense, and I'll probably do that.
Freya - You might be right.  I don't have an Oct-18 adapter to test.
Thanks!
#9 Stephen Gelb
Stephen Gelb
  • 11 posts
Posted 21 September 2017 - 10:12 AM
looks like the american arriflex mount.. cant remember the name.. very close to arri std mount, but not quite exactly the same
#10 Dom Jaeger
Dom Jaeger
  • 1696 posts
Posted 22 September 2017 - 01:56 AM
Yes, that makes sense, a Cineflex mount. Great thinking!
#11 Chris Lange
Chris Lange
  • 61 posts
  • Minneapolis, MN
Posted 22 September 2017 - 07:56 AM
Cool - Thanks!  Definitely seems to be Cineflex mount.
Also tagged with one or more of these keywords: vintage lens, old lens, baltar
