165 degree shutter 50hz flickering
#1 Juha Mattila
Juha Mattila
  • 57 posts
  • Finland
Posted 15 September 2017 - 06:14 AM
Hello all,
Im sorry if this subject have been covered already but I couldn't find fully comprehensive answer to it.
I have Arri IIB with Tobin crystal motor and I need shoot on location under the prevailing lights. Most likely fluorescents. Some say you can shoot 25fps 50hz lights with no problem at 165 degree shutter but I have also reed that it can still produce flickering. Before I do the test I wonder if some one has already done it or knows how it is?
Thank you,
Juha
#2 Stuart Brereton
Stuart Brereton
  • 3331 posts
Posted 15 September 2017 - 09:49 AM
If you're in a 50hz country, you should shoot at 25 fps with a 180 degree shutter. With fluorescent lights, it is possible that they may flicker due to old, magnetic ballasts. There's not much you can do about this. If it is a single fixture, you can just turn it off, but if it is multiple fixtures, it is likely that they are all flickering at different rates, which makes it impossible to compensate for.
#3 Simon Wyss
Simon Wyss
  • 1474 posts
  • Basel, Switzerland
Posted 15 September 2017 - 11:42 AM
You want 172.8 degrees shutter opening angle at 24 f. p. s. in a 50 Hertz grid.
#4 Juha Mattila
Juha Mattila
  • 57 posts
  • Finland
Posted 16 September 2017 - 04:09 AM
Thanks guys! That was what I was afraid of. I just have to rent a camera then. It's a shame that I cant use my own IIB for that kind of locations...
