Scalca Stabiloid + Easy grip - vertical stabilizer for cars
No replies to this topic
#1 Dmitriy Scalca
Dmitriy Scalca
  • 4 posts
  • Grip
  • Moscow,Dubai
Posted 15 September 2017 - 06:29 AM
First - "Scalca Easy Grip"
SCALCA Easy Grip – It is revolutionary unique solution, which was developed for vertical liner stabilizer Stabiloid ( or any other stabilizers) mounting on the vehicle quickly and usefully.
The kit includes special vacuum cups, which allow to mount "Easy Grip" on any surfaces of the vehicle. "Easy Grip" construction includes the light alloy pipes with diameter 45mm and length 500-600 mm, allowing increasing length of the pipes quickly if it is necessary. Pipes connection is provided with special clamps, which can be fixed by hand quickly and without forcing exertion – you no longer need any hex driver tools. The kit is packed in the compact case, which is convenient in transportation.Your gripping devices always is ready to start working.
Scalca Stabiloid Arm
Scalca Stabiloid is the multipurpose vertical liner stabilizer for electronic stabilizers such as DJI Ronin, MOVI and other gimbals. This one allows removing problems with vertical stabilization (4th axis) completely. Set of Scalca Stabiloid includes the vibration isolation damper, which improves quality of shooting in motion.
Scalca Stabiloid key benefits are:
- Weight 7kg(15 lb),payload 15kg(33 lb)
- complete compatibility with standard tubes (diameter is 45-52 mm);
- quick mount by applying 2 aluminium clamps;
- install ability on the one tube;
- adjustment for different equipment weight;
- small size and weight for transportation;
- accordable cable anti-vibration damper;
- suction cup auto grip system is developed specially for tubes quick mounting;
- adjustment possibility angle of the tubes;
During the buying Stabiloid and Easy Grip you have one case with 30 kg weight, where there is all what you need for the gripping the Stabiloid on the any car and any gripping point. You don't have to buy anything additionally.
