Shooting into the sun
#1 Tiago Pimentel
Tiago Pimentel
  • 159 posts
  • Lisbon
Posted 21 September 2017 - 08:14 AM
Hi guys,
Not sure if this is a question for the lighting forum, but here goes. When shooting directly into the sun (thinking mostly of Malick/Lubezki approach), while filming a face in between the sun and the camera (covering and uncovering the sun), I usually run into a problem of contrast and lack of sharpness and detail in the face. Almost as if the sun creates this glare which affects the contrast of the subject I'm filming.
Is this just a matter of having the right lens and lens coating or are there any other cinematography techniques I should be using?
#2 Brian Drysdale
  • 5331 posts
Posted 21 September 2017 - 09:51 AM
On one of the Malick films they used  Zeiss Master Prime and Ultra Prime Lenses, which are pretty flare resistant
What lenses are you shooting with?
#3 Tiago Pimentel
Tiago Pimentel
  • 159 posts
  • Lisbon
Posted 21 September 2017 - 10:41 AM
Yeah, those were the lenses used on the Tree of Life. Since I don't have the money for those, I'm using a Sigma 18-35mm for this effect. I will try with my Zeiss 1.4 Planar 50mm. Maybe the results will be better.
#4 Brian Drysdale
  • 5331 posts
Posted 21 September 2017 - 11:02 AM
A zoom will usually flare more than a prime lens.
#5 Tiago Pimentel
Tiago Pimentel
  • 159 posts
  • Lisbon
Posted 21 September 2017 - 12:42 PM
Thanks Brian. So the loss in contrast is attributed to lens flaring? I have a tokina 28-70 based on an old angenieux formula that i absolutely love but flares like hell. I once tried to use it for this kind of shot and it looked terrible. I will try my zeiss. Thanks!
#6 David Mawson
David Mawson
  • 94 posts
  • Manchester
Posted 23 September 2017 - 04:54 PM
The fewer elements you have and the better they are coated, the less flare. (But lens elements are there for a reason.) Reflection off the inside of the lens barrel is also a factor. Obviously, zooms tend to have more lens elements.
#7 Tiago Pimentel
Tiago Pimentel
  • 159 posts
  • Lisbon
Posted 26 September 2017 - 07:21 AM
I've noticed a similar problem when shooting against light coming through lots of haze. I don't even have to shoot directly against a light. If there's haze in there, it all turns into a big white blur. If i close down the lens or include nd filters, all I get is underexposed footage. It goes from white blur to underexposed in a single stop. Is this normal? Maybe it's the IR filter I'm using that might be bouncing light and creating this weird effect?
