Cable wraps trick line plastic sleave.
Where can i find them
#1 David Ross
David Ross
  • 43 posts
Posted 22 September 2017 - 11:10 PM
Last year I did a job in Semi Valley and we hired a gaffer and sprinter van package. The truck was nicely outfitted. The gaffers AC stingers  cords had these great trick line cable wraps that were housed in a little plastic  connector type rig. He said they made these in various sizes depending on the cord type, SJO, SOO etc. Does any one know where i can order this type of cable wrap ? The closest thing i have seen one line is one offered by Barn door lighting that is called: bullet cable tie with clear window. I have attached a screen shot. The problem is that the only size offered is for soow cable and i also have many other types of 12/3 cable .
Any help would be awesome .
Thank you.
#2 JD Hartman
JD Hartman
  • 1809 posts
  • Edison, N.J. U.S.A.
Posted 23 September 2017 - 06:16 AM
IMHO they are overkill for stingers and not cheap either.  I find tying a constrictor knot with long tails sufficient.
Anyway, I don't have a direct source for them but Lex carries them, maybe try the MCMaster-Carr website.
#3 David Ross
David Ross
  • 43 posts
Posted 23 September 2017 - 07:26 AM
Thank you for your quick response. You mentioned LEX in your post, is LEX a electrical supply store? Also I was able to locate the MCMaster -Carr website but did not see them there. perhaps i wa snot looking in the correct place, However that is an awesome resource -so that you for that.
Thanks again for your  assistance.
Kind Regards
#4 JD Hartman
JD Hartman
  • 1809 posts
Posted 23 September 2017 - 03:06 PM
Lex: http://www.lexproducts.com/
#5 JD Hartman
JD Hartman
  • 1809 posts
Posted 23 September 2017 - 08:06 PM
As I recall the clamp on cable marker and rope holders were about $10 each, great for feeder cables worth hundreds of dollars. Anyway you could try: http://www.so-calvalueadded.com/cable-holder.shtml
I use a simple label under clear self adhesive shrink tubing (so does Lex for cables they manufacture).
#6 David Ross
David Ross
  • 43 posts
Posted 23 September 2017 - 11:25 PM
Thank you so much JD Hartman.
Kind Regards
