Replacing foam light seals in Super-8/Single-8 cameras
#1 Samuel Berger
Samuel Berger
  • 1229 posts
  • Seattle
Posted 29 September 2017 - 07:18 PM
Hi there,
The foam light seals inside my ZC-1000 have turned to black granules. How hard would it be to fix that myself?
Also, I need to clean the edges of the mirror. Any caveats? I know that in older Eclairs you're supposed to never touch the mirror with anything...
#2 Dom Jaeger
Dom Jaeger
  • 1890 posts
  • Melbourne, Australia
Posted 30 September 2017 - 01:06 AM
You can buy self-adhesive foam light seals, try google for a local seller. Easy to cut to fit the gap.
Reflex camera mirrors are front surface, so very easy to scratch, but if you're careful with a tissue and some isopropyl alcohol you should be able to clean it without scratching.. use one tissue per wipe.
#3 Samuel Berger
Samuel Berger
  • 1229 posts
  • Seattle
Posted 30 September 2017 - 12:10 PM
Thanks Dom, it can't be that difficult to replace, even though some of the foam is shaped like a circle. I'll have to get a caliper out and see how many millimeters thick it is.
I haven't used the ZC-1000 in over a decade. Hopefully it all runs well. I also hope the dirty edges on the mirror won't be in frame in the film. I've just purchased some of that Cinevia 100D Single-8 and it wasn't really that cheap.
It's funny how much a person's life can change in a decade. It feels good being able to get back into 8mm film after so much has changed.
#4 Mark Dunn
Mark Dunn
  • 2872 posts
Posted 30 September 2017 - 12:53 PM
https://www.micro-to.../products/lb116
The mirror doesn't affect what's on the film.
Edited by Mark Dunn, 30 September 2017 - 12:54 PM.
#5 Maik Lobborn
Maik Lobborn
  • 27 posts
  • Electrician
Posted 01 October 2017 - 03:16 PM
They are readily available here:
http://www.wittnercinetec.com/5169
#6 Samuel Berger
Samuel Berger
  • 1229 posts
  • Seattle
Posted 01 October 2017 - 04:52 PM
Thank you, the order has been placed. I thought for sure that Wittner was closed.
