Shooting under fluorescent lights
#1 Marc De Acetis
Marc De Acetis
  • 12 posts
  • TORONTO
Posted 29 September 2017 - 07:22 PM
Hello everyone,
I'm shooting a film in a month and a bit all on S16 with 250D film stock. We are shooting a scene in a department store that has all fluorescent lighting (photo below). We don't have the budget to replace all the tubes in the store and I was thinking of shooting it mostly with the natural fluorescent light for the wides but adding more fill and shape in the closeups. A possible question that would raise when I'm doing this is the flicker.  Will there be flicker? Would checking flicker from a DSLR in video mode be a suitable way of testing for flicker or would I need to play with the shutter in this instance and run some actual tests from the lab.
FcAvIEu.pngLooking forward to your responses.
Marc
#2 Adrian Sierkowski
  • 7477 posts
Posted 29 September 2017 - 08:07 PM
Generally they won't flicker-- generally, as long as you're not off speed. The DSLR trick is a good idea.
I would highly recommmend taking a color meter and figuring out the +green you need to add to your own lights so they are all the same color, roughly, to be balanced out in post.
Normally, I'd be on T film and then use a FLB filter to remove most of the green cast you typically get from cool white tubes but in your case on daylight film i'd try to source a FLD filter. Not as big a deal these days with digital post as  it used to be, though; but do make sure you match your heads with +green gels as needed.
#3 Marc De Acetis
Marc De Acetis
  • 12 posts
  • TORONTO
Posted 06 October 2017 - 08:56 PM
Thank you Adrian for the insight and the advice! Going to run a test to get some results.
