What's the best diffusion material?
13 replies to this topic
#1 Seth Baldwin
Seth Baldwin
  • 45 posts
  • Australia
Posted 10 October 2017 - 08:26 PM
Hello,
What would give the nicest result for diffusing a 1k LED panel through a 4x4 frame? What's the best matthews or rosco roll that is the best mix for retaining light power, a wide and even spread, whilst of course following the essentials of softening shadows?
  • 20254 posts
Posted 10 October 2017 - 08:36 PM
That's a bit like asking for the best & cheapest option...
The heaviest diffusion will spread the light the most and cut the most amount of light, and the lightest will spread the light the least and let more light through.  This is why one carries more than one strength of diffusion.  I'd get a 4'x4' frame of Opal, 250, and 216 for example.  Or just get 250 and plan on doubling it up when you can get away with that.
#3 Seth Baldwin
Seth Baldwin
  • 45 posts
  • Australia
Posted 10 October 2017 - 09:43 PM
Yeah I definitely took that into consideration. I really was looking for a popular in between balance so thanks for the suggestions I'll most likely just purchase the two and see what works.
#4 Stuart Brereton
Stuart Brereton
  • 3397 posts
Posted 10 October 2017 - 10:02 PM
I find I use either 250 or 251 90% of the time. Opal is good for just taking the hard edge off a lamp, although I use it more often on the barndoors than on a frame
#5 Seth Baldwin
Seth Baldwin
  • 45 posts
  • Australia
Posted 10 October 2017 - 10:20 PM
Okay, the main light source is not too spotty so I'm not to concerned on dealing with hard edges but i'll definitely take 250 into consideration.
#6 Jaron Berman
Jaron Berman
  • 194 posts
  • New York, NY
Posted 12 October 2017 - 10:30 PM
This actually brings to mind a question I've had for a while - is there a rosco/lee product similar to the material chimera uses on their LED boxes?  I've side-by-sided against opal, 250, hampshire and it's no rough match to any of them.  The chimera material looks like a prismatic to me (like the materials ETC sells for their led units), certainly more diffuse with less loss than any of the usual suspects so I'm interested if anyone knows a similar roll material?
#7 David Mullen ASC
  • 20254 posts
Posted 12 October 2017 - 10:54 PM
I thought Chimeras use something similar to grid cloth.
#8 Mark Kenfield
Mark Kenfield
  • 1202 posts
Posted 13 October 2017 - 06:43 AM
I'm a huge fan of Half Soft Frost for multi-diode LEDs. It just seems to do an incredible job of blending the multiple sources into a seamless singular shadow. It's highly transmissive, so isn't as effective at spreading the size of the beam outward to create a larger source ala 216, Full Grid or Muslin. But for keeping most of the output of a little LED unit, whilst having smooth seamless shadows, it's great.
#9 Robin R Probyn
Robin R Probyn
  • 2402 posts
  • Tokyo
Posted 13 October 2017 - 07:19 AM
Chimera,s also have different levels .. to me the nearest thing would be sail cloth (well all nylon today ).. I wonder if you can buy that somewhere before it gets made into sails.. or buy a couple of dinghy spinnakers..
Edited by Robin R Probyn, 13 October 2017 - 07:21 AM.
#10 Phil Rhodes
  • 12303 posts
Posted 13 October 2017 - 07:29 AM
I bought a bunch of parachute silk (actually nylon or some other synthetic) from eBay. It's a very light ripstop nylon, so it has the grid pattern (and the strength) but not the papery feel. About the only downside is that it doesn't necessarily behave exactly like the widely known types of grid cloth, but I can't say I regularly do setups big enough that I really need to know the specifics.
#11 Edward Lawrence Conley III
  • 192 posts
  • Los Angeles CA
Posted 13 October 2017 - 02:36 PM
For the LED boxes they use some sort of heavy vellum type of material - not the normal diffusion seen on their other soft boxes.
they call them Light Screens
"Included standard is a 30 degree lens screen that offers a medium-level of light control and very light diffusion. Optional screens and fabric grids are available for increased control."
Edited by Edward Lawrence Conley III, 13 October 2017 - 02:39 PM.
#12 Edward Lawrence Conley III
  • 192 posts
  • Los Angeles CA
Posted 13 October 2017 - 02:43 PM
LEE might have what you are looking for
http://www.leefilter...ircon-diffusion
#13 Jaron Berman
Jaron Berman
  • 194 posts
  • New York, NY
Posted 13 October 2017 - 11:34 PM
Yeah most chimeras use some variation of grid, but their Litepanels specifics have some crazy plastic sorta thing that I can't match to any material I know- like Edward mentioned it's like a heavy vellum.  Good eye on the Zircon, will have to try it.  Thanks!
#14 Phil Rhodes
  • 12303 posts
Posted 14 October 2017 - 04:05 AM
I have a pack of the Zircon stuff here. As far as I can tell it's simply designed to be more resistant to the powerful blues in LED light, which can degrade conventional filters. The diffusion is not particularly special from what I can see.
