Is this a light leak?
16 replies to this topic
#1 John Carty
John Carty
  • 29 posts
  • AZ
Posted 16 October 2017 - 06:58 PM
I have just got back my first roll of film shot on a Bolex H16  Rex1, shot on a kodak 50d film stock. I noticed a white band on the right side of the frame( as you look on the screen) and thought to myself this is not a typical light leak, as you look at the far right side you can see the edge is just to dam straight and its from top to bottom, I have attached a pic so you can see what I am referring too. Any ideas or suggestions on this matter would be most appreciated.
John
#2 Samuel Berger
Samuel Berger
  • 1229 posts
  • Seattle
Did you remember to cover the filter slot?
#3 John Carty
John Carty
  • 29 posts
  • AZ
Posted 16 October 2017 - 07:51 PM
To be honest I don't think I did, I put tape around the gaps where the back cover is I may have missed the filter slot. Does my pic look like I have?
#4 Samuel Berger
Samuel Berger
  • 1229 posts
  • Seattle
Posted 16 October 2017 - 08:28 PM
Yeah that happened to me on my first roll too, decades ago. I actually kept the film but I never forgot afterwards.
#5 Jon O'Brien
Jon O'Brien
  • 633 posts
  • Brisbane
Posted 16 October 2017 - 09:51 PM
You just keep the filter slide in the slot at all times, to avoid this light leak? Or is it best to tape over the slot openings as well even though the filter holder is in place?
#6 Samuel Berger
Samuel Berger
  • 1229 posts
  • Seattle
Posted 16 October 2017 - 10:02 PM
It depends on the state of the filter and the slot. Keeping the slide in should be enough but I would add gaffer tape over that as well just for peace of mind.
Also in Reflex models, make sure you close the viewfinder whenever your eye isn't pressed against the rubber eyecup.
#7 Jon O'Brien
Jon O'Brien
  • 633 posts
  • Brisbane
Posted 17 October 2017 - 01:19 AM
Also, is it necessary with a Bolex to put tape around the film door? I'm assuming not, since no one ever mentions it. The door on my Bolex seems to close well. I'm forever reading about pro filmmakers putting tape around Arri magazines, that's all.
#8 Samuel Berger
Samuel Berger
  • 1229 posts
  • Seattle
Posted 17 October 2017 - 01:24 AM
I don't know anyone who tapes up the Bolex unless the door is warped. On the K3 it's a different story, I have trust issues with the K3. But with the Bolex...I've never had an issue other than the filter slide not being in.
#9 Brian Drysdale
  • 5334 posts
Posted 17 October 2017 - 01:36 AM
Only time I've had to put tape around is for stop frame animation. Each frame was being individually drawn, one owner used a cover for shooting  time lapse on the Bolex.
The open filter slot is the usual cause of the band down one side.
#10 Jon O'Brien
Jon O'Brien
  • 633 posts
  • Brisbane
Posted 17 October 2017 - 02:02 AM
Is that because there's a lot of light on set, and the camera is sitting in that light for ages, Brian? I used to do stop-motion on Super 8. I got pretty good at it too, usually with clay models.
#11 Brian Drysdale
  • 5334 posts
Posted 17 October 2017 - 02:23 AM
The camera was beside the Lights, these were pointed at the drawings, but it was minutes between each new frame. I don't know if it was an issue with a particular camera, since it wasn't my camera.
#12 Doug Palmer
Doug Palmer
  • 382 posts
Posted 17 October 2017 - 12:24 PM
That fogging looks definitely the uncovered slot. The door usually shouldn't need taping, except when you're doing animation as Brian says... sometimes I've had slight fogging of individual frames if there's a tiny leak somewhere, because of the time the film is stationary before or after it encounters the gate. And this could happen at the start or end of an important normal shot.   So I generally tape up anyway for peace of mind.
#13 Jon O'Brien
Jon O'Brien
  • 633 posts
  • Brisbane
Posted 18 October 2017 - 05:59 PM
Thanks Doug for your valuable advice. One thing I wasn't clear on, though, in your last two sentences. Are you saying that for normal shooting eg. of live action footage, that you do tape up the door, just in case? I've never bought camera tape. What is the type to get? Excuse my ignorance - I was mainly into Super 8 and such details of film production weren't necessary back then.
#14 Samuel Berger
Samuel Berger
  • 1229 posts
  • Seattle
Posted 18 October 2017 - 06:01 PM
I use this: https://www.amazon.com/gp/product/B00GZE3UJ8/ But even electrical tape will work, you just need to keep the light out.
And of course, shut the viewfinder when your eye is not pressed against it.
#15 Doug Palmer
Doug Palmer
  • 382 posts
Posted 19 October 2017 - 04:57 AM
I'm probably being over-cautious, but yes any black tape will be fine. Also a reminder there's film inside :)
It's just that on one or two occasions I've had some fogging of a frame about half a second into a live action shot, caused by a tiny door leak. For most shots no problem as it could be discarded.  But if doing some special effect you might need the footage.  If you want to test the door seal,  maybe leave the loaded camera for an hour in bright sunlight and see what happens.
Also good I think to tape over the filter-holder if it's that kind on turret cameras. The other one on bayonet cameras is far better design.
Edited by Doug Palmer, 19 October 2017 - 05:06 AM.
#16 Jon O'Brien
Jon O'Brien
  • 633 posts
  • Brisbane
Posted 20 October 2017 - 07:04 PM
Have got to write up a list of remember-it points for first shoot. One is, shut viewfinder off when taking eye away. Have decided I will do a bit of taping here and there on door and filter slide. I think the reminder that film is in there is as good a reason as any, and the pros do it, too.
A short poem:
My tripod quest bore fruit
It is now
Time to shoot
#17 Dom Jaeger
Dom Jaeger
  • 1886 posts
  • Melbourne, Australia
Posted 20 October 2017 - 09:36 PM
Yes time to put these tips to use
Now take that fruit and make some juice!
  • 1
