Bad telecine from negative?
9 replies to this topic
#1 Mike Lary
Mike Lary
  • 472 posts
Posted 01 July 2005 - 11:57 PM
Hi all,
I just had some Kodak 7222 Double-X Negative telecined with scene-to-scene correction and transferred to uncompressed QT and the results were horrible. :o The highlights are blasted out and there's some nasty posterization. The neg looks really sharp on a lightbox viewed with a loup (it's the best I can do without a print). Three rolls of reversal that were transferred on the same order look really good, so I'm wondering if the operator might have set a best light for the reversal and not made an adjustment for the neg. :unsure: Can someone with telecine experience please take a look at these images and tell me what you think the problem might be?
Here are some samples of the bad transfer, full resolution at highest jpeg compression.
http://www.oxygenhab...ecine/bad03.jpg
http://www.oxygenhab...ecine/bad02.jpg
http://www.oxygenhab...ecine/bad01.jpg
And here is one of the good transfer.
http://www.oxygenhab...cine/good01.jpg
Thanks in advance for your help,
Mike
#2 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 02 July 2005 - 04:25 AM
Hi all,
Mike
<{POST_SNAPBACK}>
What was the telecine?
Stephen
#3 Sam Wells
Sam Wells
  • 1751 posts
Posted 02 July 2005 - 09:57 AM
Well the reversal looks like Plus-X, that's a big help !
(If it's Tri-X I'd be really impressed actually).
Yes - what Telecine ? Makes a dif in 16mm especially.
The reversal sotcks - PXR and TXR ARE sharper, and that difference really shows up in 16mm.
As for setup, I dunno, the lower gamma of the negative should make it easier. Bad03 is too hot, plus it's clipping hard.
-Sam
#4 Mike Lary
Mike Lary
  • 472 posts
Posted 02 July 2005 - 11:18 AM
Hi Stephen. It was a Cintel, either DAV Turbo or MkIII.
Mike
#5 Mike Lary
Mike Lary
  • 472 posts
Posted 02 July 2005 - 01:00 PM
<{POST_SNAPBACK}>
Hi Sam,
Yes, the reversal stock was Kodak Plus-X.
Is Cintel a bad choice? If so, which telecine process would you recommend for Double-X Neg? My motivation for switching to neg was to take advantage of the wider exposure latitude, and I plan on telecining my next project straight from neg.
Mike
#6 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 02 July 2005 - 01:39 PM
<{POST_SNAPBACK}>
A Cintel Mk 3 with a new tube can look great! Noiser than a Spirit for 16mm. A Mk 3 with a worn out tube or run with low beam current looks very bad. I would ask for your money back for that transfer!
Stephen
#7 Sam Wells
Sam Wells
  • 1751 posts
Posted 03 July 2005 - 10:25 AM
Well it's always a question of which Cintel - there are so many out there, varianys, age issues.
I rather like C-Reality but those are newer macines - and - you'll get a grainier look with that. I think a Spirit might be the best choice for 7222.
-Sam
#8 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 03 July 2005 - 11:44 AM
-Sam
<{POST_SNAPBACK}>
I prefer the C- Reality to a Spirit but the local facility sold the C-Reality and bought a Shadow!
Stephen
#9 Dominic Case
Dominic Case
  • 1357 posts
  • Sydney Australia
Posted 03 July 2005 - 07:31 PM
Looks like the telecine wasn't set up for b/w neg properly.
B/W neg is considerably more contrasty than colour neg.
All b/w increases in contrast when printed or transferred with specular (ie higly directional) light. A Cintel would be worse for this than a Spirit for example.
#10 Mike Lary
Mike Lary
  • 472 posts
Posted 04 July 2005 - 07:27 PM
Thanks, Dominic. They sure didn't correct shot-by-shot as promised, so it wouldn't surprise me if the setup was wrong, too.
I guess I'll try a Spirit transfer next. Thanks for the input, everyone.
