Tobin TTL Accessory jack
#1 dancordle
dancordle
  • 34 posts
Posted 03 November 2017 - 12:21 PM
I own a Tobin TTL (connected to a Konvas 2M) and can't find information on hwat kinds of accessories can be plugged into the accessory port/jack. I'm wondering if I it can be used to synch with a flash or to take synch photos with a DSLR camera. Has anyone here used the accessory jack?
#2 Glenn Brady
Glenn Brady
  • 331 posts
Posted 03 November 2017 - 06:49 PM
Here's a .pdf of the TTL instruction manual http://www.urbanskif...lic_PDF/TTL.pdf
#3 dancordle
dancordle
  • 34 posts
Posted 05 November 2017 - 06:06 PM
Thanks, I'd seen that manual but it lacks specific information about the accessory jack. I've since communicated with Clive Tobin (many thanks to Clive). Here is what he said, in case anyone needs the information in the future:
"The Accessory jack is intended for running a Bolex torque motor that does not draw too much current, or a relay for turning on lights. The output is something like 8 volts DC which may suffice to trigger a still camera. I don't think I have any information on what voltage or connection would be needed to trigger the still camera. If you need a contact closure instead of a voltage you could use a little low-current relay for this."
